Results 1 to 2 of 2
Thread: Filter Change
    North West Tasmania
    Filter Change
    Hi,
    how often should the various filters be changed on the disco?
    I service every 10,000 and change the oil filter I was wondering how often to change the centrifugel and fuel filters?
    Piddler
    I have a plan which works out that you approx. halve the recommendations of LR. The half recommends are for oils & filter.
    Change engine oil @ every 10,000 K's
    Change centrifuge filter @ every 10,000 K's.
    Change full flow filter @ every 30,000 K's.
    Change diffs oils @ every 60,000 K's.
    Change transfer oil @ every 80,000 K's. (LR recommended)
    Change radiator water @ every 40,000 K's.
    Change fuel filter @ 40,000 K's. (LR recommended) The water sensor is brittle and does not like to be removed & replaced. Also $130 each...you don't want to stuff it up each time you change the filter 8O
    It works out to be a bit more expensive but you know that it will last the distance and should not cause you any problems.
    Lyndon.
