Results 1 to 10 of 36
Thread: Engines? No manual box?
    Jan 2017
    wollongong
    Just looking at the new Disco specs and LR list 3 engine choices:
    TD4 2.0: 132kW, 430Nm
    SD4 2.0: 177kW, 500Nm
    TD6 3.0: 190kW, 600Nm
    And one gearbox choice:
    8 speed auto
    Plus option of 2 speed transfer box with centre locking diff (with air suspension) on SD4 and TD6 engines. Optional rear locking diff too with the 2 speed transfer box.
    Assuming a lot of Disco technology will be shared with the new Defender, but LR will hopefully try to keep costs down and off-road ability high, would the TD4 engine + 8 speed auto + 2 speed transfer box (minus air suspension) be the most logical combination?? Purely speculation I know, but anyway. Cheers
    Feb 2005
    Surely it will have air suspension....
    Williams West Aust
    I would think,and hope the new one will be a re-bodied D4,at least it would keep the D4 owners happy
    Pretty sure the coil version was dropped along with manual trans after the early D4s.
    Shame the D4 commercial never came to Australia.Ive removed my 3rd row and the 2nd row is always folded down.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    May 2003
    On The Road
    maybe their newer 8 speed will be the one,,
    with 8 speeds covering lower and upper transfercase ratio's
    surely we dont need 8 lowrange ratios Andy?
    Williams West Aust
    They have just put a 10speed auto in the new Mustang.
    Andrew
    Perth WA 6149
    I like the idea and removing the transfer case would make for a simpler drive train.... not to mention a whole new forum debate which always happens when technology changes
    Just have to find the ratios as they aren't in the brochures on the landrover web site.
    Steve
    St Helena,Melbourne
    1.13 MB
    Andrew
    Only if the D4 goes on a huge diet and loses some fat but i do like the idea.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Oct 2014
    Adelaide
    You would have to expect auto if they want to keep terrain response. It is the only way the software and hardware can collaborate properly. You can't have a human changing gears against the will of the software, OMG
    In regard to weight I find this fascinating particularly in regard to both off-road durability and fuel consumption. We just got back from a little jaunt from Adelaide to Caloundra and return. On the outbound trip we towed the Ultimate to its new owners and got our normal 14.9l per 100km or 530km from the tank. On the way back and regardless of travelling during a national heatwave, we got 800km out of the tank. We sat on 112kph and cruise so I was not driving for efficiency and the AC was working all the time.
    So with that sort of fuel consumption I have no problems if they use the current or I mean now old version of the chassis. Given some comments on this forum regarding a broken aluminium chassis resulting from a snatch recovery and if it is actually a fact then for those of us who spend a lot of time off bitumen I have a hankering for strength and if it means the same weight I am OK with that right now
    Fascinating to see how this model actually develops
    Rob
    Rob
    MY15 TDV6. Compomotives with KO2's, Traxide 160-DBMS, Llams, OE bar, custom rear storage slide, Rhino roof storage system, LSM TPMS, ICOM 440N, rear ladder and GOE compressor guard
    SBD4's Avatar
    SBD4 is offline A Keeper of the TGO Gold Subscriber
    Dec 2011
    Bundeena
    If it is the 8 speed transmission used un the current vehicles then it will have a transfer box. The gearing is not low enough to compete with low range and .... the ever present argument of reveresing a heavy load without low range.
    Almost guaranteed it will have low range and if they are smart they will also include locking differentials of some sort - at least at the rear. While TR is very clever, a locked diff does not need any thinking time. Makes for more steady progress I think having observed discos with and without an e-diff tackling the same terrian.
    Sean
    May 2009
    Disco 5 has coil susp/cloth seat option from memory
