Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Thread: High Comp 4.6 Straight Gas. What to use to return to straight fuel
    Oct 2014
    Hi Considering buying a classic with top hat liner fitted low km 5.6 but runs straight gas.
    Would like to return to straight petrol as it is a play car.
    Recommendations for ecu to run this
    1976 LR 90 Hybrid GONE
    1985 RRC chev GONE
    1997 D1 V8 GONE
    1973 RRC Gone
    1980'RRC Build in progress GOING
    Disco wrecking 93 & 94
    1993 RRC LSE
    May 2012
    Adelaide Hills, SA
    I don't know how
    As stated above I don't know how to do it but the ignition timing will be advanced a long way to run straight gas to its best benefit.
    You would have to make sure the ignition timing was returned to standard to make it work properly. That is if they had advanced the timing.
    Mike
    What manifold system does it currently have - can be almost anything?
    Without the information ,
    i`d pressume it is running a form of injected lpg because of the question ?
    If so it is probably piggy backing the petrol ecu ?
    The std 3.9 Rover ecu can be modded for a 4.6 if the need is felt .
    Our RRC with a 4.6 has a 14CUX that has been altered by Davis Motor Works
    The ECU alters fuel and not ignition so i`d consider to be worth while it would need to be used pretty hard , or do alot of heavy towing ETC .
    If it`s basically std Rover and it has a distributor and as has been suggested the advance has been altered for lpg , it would need changing back to a petrol curve .
    I guess 5 is beside 4 on the keyboard ?
    Oct 2014
    Oops yes a 4.6.
    Std 3.9 Manifold with gas injection in injector location.
    LPG makes sense but not available in the bush.
    Will get more info.
    1985 RRC chev GONE
    1997 D1 V8 GONE
    1973 RRC Gone
    1993 RRC LSE
    Ok so if it has the 4Cuix system I guess they also put the 3.9 dizzy and timing cover on the front.
    Then as suggested by PLR, the 4CUIx ecu is probably there some where, if not source one and get it chipped for the 4.6. I am also guessing you will need to get injectors etc. You will need a MAF as well etc. Timing at around 9-10 degrees BTDC will work with both gas and petrol but the new tuning process will sort that.
    Guessing a bit as specific details of what you have is still not totally clear.
    As a suggestion - why not take it back to dual fuel - Put the petrol injectors back where they belong and get the manifold modified to take the gas injectors - best of both worlds.
    Oct 2014
    Would prefer straight fuel for availability and one system
    1985 RRC chev GONE
    1997 D1 V8 GONE
    1973 RRC Gone
    1993 RRC LSE
    Oct 2014
    Motor is a fully rebuilt 4.6 block with shaved 3.9 rebuilt heads and running straight LPG.
    Bottom end was rebuilt by Speed Works in Ringwood. It included brand new High comp pistons (almost the last ones you could buy in AUS), all new conrods, and new bearings.
    Heads were reconditioned by Fred Smith and shaved so the bowl suited the 4.6 and compression was not lost
    Injector holes were blocked up, I think resin or sikaflex or something permanent so that might not be possible. Putting it on carby would work but not very efficient.
    If you could get fuel rails, injectors in you would still need all the sensors ( I think there were 3 or 4 that are necessary) ecu and all relevant wiring.
    1985 RRC chev GONE
    1997 D1 V8 GONE
    1973 RRC Gone
    1993 RRC LSE
    Oct 2011
    Sunshine Coast
    Sounds like a very nice engine. Maybe one of these on it would be great fit modern simple and would go well. The second one that does ignition timing as well
    fitechefi.com/
    Oct 2011
    Sunshine Coast
    The GoEFI4 - read the reviews you can actually use it on any horsepower from 150 up. US$995 which for complete new self learning EFI unit is pretty good value. That teamed with your solid engine would be a really nice combination you'd think
