Results 1 to 10 of 12
Thread: Extending range of radio coverage
    Alstom 888M Guest
    Hi all, first time poster.
    I would like to find a way to extend the range of my cars radio. Disco 2.
    Would a different antennae help? I like to travel to remote outback areas when I'm on leave.
    Williams West Aust
    Welcome Aboard.
    When I had a D2,its reception was generally good in rural areas,but it was an Alpine unit with a stacker.
    Check your glass antenna,rear rhs glass to see in the wires are connected and also look at the tracks on the glass for scratches/breaks,you can get a fix for these,look for the repair glue for rear window demisters.
    You can buy a CB style antenna for roo bar or bracket mounting if need be.
    Must admit the reception in my D4 on AM or FM for that matter isnt as good as the D2.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Jan 2011
    Gippsland
    Quote Originally Posted by Alstom 888M View Post
    G'day, I researched this as well and will buy an antenna from here ...
    Mobile One Antennas
    I have no affilliation with Mobile One apart from them being my first choice when I'm purchasing AM/UHF CB antenna's over what is for nearly 40 years. Their only negative point is that they're not theft proof
    LROCV member #131
    1999 build D2 TD5 Auto, Mantec snorkel, 2" LRA spring lift, ARB on board air, Ashcroft ATB, CMM air ram CDL shifter, swag & gold pans ....
    Bunbury, WA
    The d2 radio antenna is in the rh rear glass with an amplifier. For one trip away the fridge in the rear interfered with the radio reception. The aerial plugs into the rear of the radio with a normal plug so I just plugged in a new aerial and ran the lead up and mounted an aerial on the roof rail. Had much better reception than the glass aerial, even with the amplifier bypassed.
    Alstom 888M Guest
    Thanks, so it's as simple as mounting a new antennae? Is there a certain type I should look for? I mostly listen to AM talkback radio, footy, cricket, etc.
    Are there any other variables i.e. head unit?
    Jun 2008
    The new Gold Coast, after ocean rises,Queensland
    Mate , I have been driving through and across Australia for 45yrs and I don't think AM reception has improved at all in that time , regardless of aerial types.
    I have a list of radio station frequencies in am and fm and I tune my car radio to those frequencies in order of distance over my trip. it doesnt take very long to do and most radios have that function .
    Its interesting that triple has just about the best national coverage on fm.....if you like jjj
    Oct 2007
    Wantabadgery, N.S.W.
    Welcome to the forum. Further to what Onebob has posted above, on the link he's put up, scroll down to near the bottom. The M2W antenna is 5' (very long), is tuned for AM/FM and will suck signals in from vast distances. You will not be disappointed. If you ring Mobile One and talk to Peter, you'll get answers to all your questions, he's very knowledgable and helpful. And no, they're not paying me.
    Don.
    IF you listen to AM radio I wouldnt be worryign about getting a new antennae for it.
    AM radio is being defuncted in the nearish future, with FM not being too far behind.
    AM to stay in Aus.
    Hi All,
    Being in a state that has yet to get DAB+ I have sort of been following the scene.
    Just recently there was a statement made that finally there would be a roll-out of DAB+ in the Hobart, Canberra and Darwin (I think?) areas.
    It also stated that as opposed to other countries where FM and AM were being withdrawn, Australia would keep all formats.
    This reflects the population densities, the distances between population centres and the terrain.
    So, hopefully AM will be around for a while yet.
    I thought, and dont quote me, the AM/FM phase out was because that chunk of the spectrum was being re purposed.
    If the rest of the world starts using it for something else I dont think we'll get much of a say.
