You can use a shunt and a dual Amps/Volts meter. that links to the shunt.
Take a look around eBay. I got a couple for something like $25 each (from memory). I can see what's going in and what's going out.
Pretty simple to set up.
I need to get some sort of o/p monitor to keep check of voltage and current being supplied to the battery. What types of devices are available to do this? Jim
Jim VK2MAD
'17 Isuzu D-Max
I got one similar to this: Type 2 in 1 Digital Amp Volt Combo Current Meter tester 2 Color with shunt 50A | eBay
Thanks Spudboy, ebay is too easy. $13.85 and one is on its way![]()
Jim VK2MAD
'17 Isuzu D-Max
