Results 1 to 8 of 8
Thread: Asus K52 battery or charging problem
    Brisbane, Queensland
    My wife has an old Asus K52 laptop that has been kept working longer than expected by fitting extra RAM, a SSD, and after replacing the keyboard and DVD drive. I did all this work so didn't cost a heap. It still works great and does everything she wants, other than it doesn't hold charge or recharge.
    I recently took a punt on a new battery from a Aus eBay seller. The battery lasted about a month before it started run down too quick too early and wouldn't recharge. The light on the charging transformer didn't light up so I bought a new charger, which seemed to work (light came one) but the battery wouldn't charge. I blamed the battery and got a replacement which drained quick and after a few days wouldn't charge.
    Have I bought a battery from a dud ebayer or is something else wrong and can I fix it?
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    May 2003
    On The Road
    At work recently we sold off 20 or so dead lappy batteries, which was fine as the laptops were never going to sell anyway
    are you sure it was "new"
    Battery was sold as a new battery.
    REMLR # 137
    I once bought an eBay charger to charge my Li camera battery while in the car. It didn't charge the battery despite the little led lighting up. I knew the battery was OK because I could charge it from the 240v wall charger. The unit was unbelievably light in weight, I opened it up to see what was in there - a resistor attached to an led.
    Luck buying eBay phone batteries is just as bad. What are supposedly genuine batteries are genuine fake batteries in my experience - they fit but don't perform.
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
    Sep 2012
    Adelaide Hills
    install batterybar
    https://batterybarpro.com/
    and once installed, check the battery wear and charge rate
    Current Cars:
    2013 E3 Maloo, 350kw
    2008 RRS, TDV8
    1995 VS Clubsport
    Previous Cars:
    2008 ML63, V8
    2002 VY SS Ute, 300kw
    2002 Disco 2, LS1 conversion
    Thanks Gents. I'll see how I go with the battery bar.
    REMLR # 137
    I consulted the techs at work. The resolution was the motherboard needs replacing. Anyone know where to buy one for an ASUS K52? I'd rather not spend $800 on a new laptop.
    REMLR # 137
    May 2003
    On The Road
    China?
    no seriously, I upgraded my old ASUS's ram and CPU and it all came from there,, seems to work fine too
