Better in tight rough stuff and better re-sale value
Hi,
I have a LR4 2012 SVD6 256 HP 8 speed UK Model.
It came with central diff but not rear. It was a second hand car and I didn't have the chance to add it on.
I have done an extensive research and it can't be installed as aftermarket. There is a company in Italy/Germany (Mudtech4x4) who is studying the option of retrofit one. In case I even found one.
I am loosing sleep on it (obviously for no reason)
Is it worth? On three separate of occasions I got stuck and I thought that with a read lock this probably wouldn't have happened. On the snow, on soft sand, on wet rock climbing (a mayor step to take). While I agree that the TC is extremely capable I still think that two parallel wheels spinning together in extreme situations (as above) will work better. TC, even when off, won't give that boost that you need to overtake certain obstacle or tricky terrains.
Am I wrong?
There is no doubts that in Australia you have more experience in using LR4 off road. Please educate me!
Nic
While the rear locker definitely adds capability for most situations (particularly sand and even snow) my guess is your tyre pattern, profile and pressure will have more effect on your available traction than a rear diff lock.
What tyre size and pressures are you running in sand and snow?
For the rock step or scrabbly incline the rear diff lock is definitely an advantage, but versions without will go almost as far as those with.
Dan
Dan You have a point. However, generally speaking you compare cars with same tyres and wheels.
I run 255/55 19 Cooper Zeon LTZ on standard pressure. In snow I use Vredestein Wintrac Xtreme same size and pressure.
However when I got stuck on the wet rock climbing, my mate was on the same car but with much better tyres: Cooper STT Pro 275/65 18 on Compomotive wheels. He got stuck the same. On the rear axle one wheel was spinning the other was blocked!
N
If your tyre pressures were full pressure then I am not surprised you struggled on wet rock...
My experience with my D3 was that a rear diff lock would only get you %% further than without. What it did do was make the other 95 % of situations much easier.
Would I fret about not having one if I already owned a vehicle without one fitted? No
Would I order one with a new vehicle or make it a significant requirement for a second hand one ? Absolutely.
Have a look at this video:
https://www.youtube.com/watch?v=GECmf0B-vT0
The Black RRS does not have a rear diff lock and on the day it was obvious that the diff lock equipped cars did things just that bit easier. For comparison my vehicle was the Atacama Sand D3 with the tyre on the roof.
Regards,
Tote
Hey Dr LC8.
Here's a thread about tyre pressures and rear diff locks
http://www.aulro.com/afvb/l319-disco...omparison.html
As said it definitely helps, but the lack of it shouldn't stop you in most situations.
Hope that info helps you make the call
Dan
Also the RRS in Tote's video is from memory a 2005 model. The Terrain Response and Traction Control has come along way in 10 years and is much better, closing the gap to eDiff equipped vehicles.
Your research has not been sufficiently extensive as it's quite simple to retrofit, with the biggest hurdle finding a complete rear diff with the correct ratio supplied with at least the connectors with wire stubs although wiring right through to the RDCU would best. However the D4 e-diff driveshafts with their stronger CVs should also be fitted.
I have just the diff itself left to fit to my MY12 L322, with the control unit fitted, wired and enabled in the CCF. As the RDCU came from a different vehicle to the diff, the diff will have to be calibrated to the RDCU.
x2. Lower pressure is the best way to increase traction. If you haven't tried it, do a test in the garage on level floor. Measure the tread contact area on the floor at full pressure, the air down say 10psi and measure again, then do another 10psi and measure again. The tread contact area will increase enormously. Just make sure you slow down with lower tyre pressure. Here's a vid showing the effect on the beach but it applicable to rocks as well.
https://www.youtube.com/watch?v=X75zqoaWhjU
Rod
D4 MY16 5 seat TDV6 - LLAMS, Custom Drawers, OL Bar, Toyo Open Country, GOE Rims, Lithium DBS, eDiff, OA Long Range Tank, GAP Tool, Tracklander rack, Mitch Hitch, TPMS & Safari Snorkel
