Thread: The "bugger off thieves" spotlight mount
    Forty minutes closer to the hills in a house the bank is kind enough to let me live in
    The time came for me to put some better lighting on the Disco, but the one thing that put me off doing it sooner was the prospect of having yet more stuff stolen. Solution - make the lights removable, but secure when fitted. See pics below for what I came up with. More fun with the welder.
    The lights installed:
    The lights are Lightforce RM170s which are very very bright, sourced through work. They sit on a removable rail as a pair.
    Each side is secured with a butterfly nut and a 5mm shackle padlock. The mounts are stacked on top of the recovery hooks, whose bolts are done up very tight and would be extremely hard and time consuming to remove from the car. Better still, the would be thief will be under the car with only his knees visible... No problem, I can work with knees.
    The light rail removed. The main bolts holding the lights to the rail are not accessible when the lights are mounted.
    All that's left when the lights are removed. The wiring can be tucked back into the grill.
    Detail of the mount.
    The wiring is all tapped directly off the battery with heavy duty 30A lines kept as short as possible. The relay is next to the overflow tank. The right hand high beam powers the relay, and each spotlight is run on seperate leads.
    Neatly located switch positioned to allow operation without taking hands off the wheel.
    Another view from further back. The rocker switch is illuminated, not that you'd miss that the lights were on! At least it will show any breakdown in the low current side of the circuit.
    All in all I am very pleased. The lights are extremely bright and can be focussed to vary spread. When angled up, view into the distance would be about 500m. More than enough to see the wildlife.
    Jul 2003
    Nice job.
    BTW I have the same Lightforce jobbies on mine. I bought a wide beam diffuser for one of them...very good.
    Mahn England
    Ex 300Tdi Disco:
    That's something I had thought about trying. How diffuse is the spread? The one issue I have with the standard beams is that while they spread a bit, the main focal point is so bright it makes it hard to see anything else.
    Jul 2003
    Yep I was dazzled by cat's eyes and road signs but it makes night driving a breeze.
    These photos were taken with the lights about 2 metres from the wall:
    No diffuser
    Diffuser on
    and perhaps more revealing with the diffuser rotated 90 degrees:
    I'll have to adjust mine....too low :roll: .
    BTW the illuminated switch is a good idea.
    I have one but I like your's more. Where did you get it?
    Mahn England
    Ex 300Tdi Disco:
    preston
    did you realise most auto alarms can be be wired so that removal/unplugging of the spotties triggers the alarm.
    jaycar even sell the kit quite cheap
    david
    That is something I might look into actually. Considering that most intrusion alarms are tripped by the interior light circuit it shouldn't be too hard.
    However, the main reason that I wanted to have everything lockable/removable is so that when I go hunting and leave the truck for a day or two somewhere the local idjets can't help themselves so easily. I have a couple of mates who have had stuff knocked off from their vehicles when going trailriding or hunting.
    I hate thieves!!!
    Queensland
    Nice neat job MacMan and good pics, you should put it in the project section.
