Results 1 to 10 of 25
Thread: Bad experience using thin 'flexible' solar panels
    Adelaide Hills - SA
    If anyone is thinking of using those thin (1.5mm thick) flexible solar panels, well my advice is don't bother.
    I put 600W (6 x 100W panels) on top of my truck to supply both 12V and 24V systems (400W for one and 200W for the other). I chose them for being light-weight (1.5Kg per panel) and low profile. To start with they were fine, probalby for the first year or so.
    After 3 or 4 years they are putting out bugger all power, like less than 1A on a bright sunny day.
    The surface has gone all chalky, so that can't help either.
    The manufacturer is not interested in giving me a refund, even though they supposedly came with a 10 year warranty. That looks like it's going to be a bunfight.
    So I've just forked out for replacement panels of the standard garden variety solar panels, which weigh a lot more and are a lot thicker, but they'll probably keep generating power for a whole lot longer.
    David
    Apr 2016
    Country Vic.
    Brother and I have been looking a a small solar system for when camping.
    We liked the 'compactness' of those flexible roll up panels.
    Good to know.
    Quote Originally Posted by spudboy View Post
    David
    LOL!
    Probably some cheap quality plastic coating, not properly UV stabilised.
    So, it seems, they appear to breakdown under the conditions that they're meant to operate under!
    Hope the warranty issue works out for 'ya.
    May 2014
    Tamworth NSW
    What brand?
    Are we are talking about the $700+ ones that are Red, don't Arc, and fold up into a neat little package? Or some chinesium alibaba junk?
    -Mitch
    'El Burro' 2012 Defender 90.
    May 2003
    On The Road
    I would've thought 3-4 years ago, 1.5mm panels would have been quite exxy to buy---
    Adelaide Hills - SA
    They were 'generic' solar panels from our local specialist 12V shop, so no, not the RedArc unfolding ones, or nasty eBay ones.
    Cost was $250 each, so $1500 for the 6 of them.
    They look like this:
    Sep 2012
    Adelaide Hills
    thats disappointing to hear.
    who refused the warranty? the seller or the manufacturer?
    what was the reason given?
    Current Cars:
    2013 E3 Maloo, 350kw
    2008 RRS, TDV8
    1995 VS Clubsport
    Previous Cars:
    2008 ML63, V8
    2002 VY SS Ute, 300kw
    2002 Disco 2, LS1 conversion
    Oct 2003
    Montrose, Vic.
    Hopefully my cheapy that I bought last yer wont go the same way:
    Camping solar for the D4
    But if it does, at least I'm not likely to be relying on it for long periods of time and I ended up buying a decent regulator, so I have the basis of something better if i have to improve the panel.
    Mine supposedly come with a 25 year output warranty.... but who knows
    https://www.vicoffroad.com.au/sport-...ging.html.html
    Mark
    2003 D2a TD5...gone...
    2000 D2 V8...gone...
    https://bymark.photography
    when you strip them down older style "traditional" solar panels are nt actually all that thick. its all the other layers of material that go to strenthgening and supporting them so they dont bend, flex and crack the power making part of the panel making high resistances and open circuits.
    Oct 2007
    Brisbane West
    Just purchased one of these roll up 100w.
    Oct 2007
    Brisbane West
    But only for camping not to be put out day after day after day...
    Heavy little tiger though. But small pack. Cheers
