Results 1 to 8 of 8
Thread: D3 standard car alarm
    May 2008
    Perth / Thornlie
    Hi guys, can't find a thread on this one.
    My 08se alarm started going off for no reason a couple of weeks ago.
    Once every couple of days.
    Now twice or more every day.
    Has anyone had the same problem.
    Is there any sonic detectors inside the car.
    What is there to check?
    Thanks for reading.
    Bruce
    Sep 2009
    My mate with a D3 had the bonnet switch causing this. Water ingress into the switch due to its location and orientation.
    May 2008
    Perth / Thornlie
    Thanks for the heads up on the switch. Just have find it. Have to start somewhere.
    Jul 2013
    As your looking into the bonnet from the front, left hand bonnet catch has the bonnet sensor. I removed and bridged mine out as it was faulty and setting the alarm off at random times
    Shane
    2005 D3 TDV6 loaded to the brim with 4 kids!
    http://www.aulro.com/afvb/members-rides/220914-too-many-defender-write-ups-here-time-d3.html
    May 2008
    Perth / Thornlie
    Yep, found it where you said.
    Guess what. Mine was unplugged. Found the other end tied back on the loom with a ball of insulation tape around the end. removed the tape and low and behold, a crasty split pin shoved across the pins.
    Cleaned it up, made it look a bit better. Got rid of the corrosion.
    Replaced the bundle of tape. See how we go.
    Thanks for the replies
    Bruce
    Dec 2011
    Adelaide
    I had this issue a year or 2 ago on my 08se also. As mentioned, it was the bonnet switch. A very cheap (Jaguar) component and easy to replace...
    Oct 2013
    Ballarat
    Mine went off with a dirty great spider on the dash
    3 am checking to why didn't see it till day light
    May 2008
    Perth / Thornlie
    Red face Fixed, I think
    Went back to going off once a week, so soldered the wires together.
    No alarm now for 3 weeks.
    Fingers crossed
    Still have my Permagrin
