The Chassis was professionally shortened by a chassis builder with experience in building racing Land Rovers amoungst many other machines.
Here we can see the original chassis cut at the right place (least tapered bit) and 5 securing holes drilled on each side of each section - these will be used to secure the sleeve.
The galvanised C section makes up the sleeve
The sleeve is then finally closed with a couple of runs of weld, this method welds the original chassis back together as well as welding the chassis to the galvanised sleeve.
LRH
Disco 4 SDV6 Auto
Disco 4 SDV8 Dual Cab Project
Disco 2 M57 Extra Cab Project
Foton Tunland Cummins ISF
Disco 1 3 door 4.6 V8 Auto
RRC V8 Auto "Classic" Softdash
RRC 300 TDI Auto
Disco 1 TD5 Auto Buggy
Disco 1 300 Tdi Auto Ute
SAME Explorer 70HP 4x4 Tractor plus Nell Loader
Subaru GDA WRX
Triumph Bonneville SE
Yamaha TTR250
