Results 1 to 10 of 21
Thread: who is this chip?
    Eidsvold QLD
    who is this chip?
    Heard on the grapevine that some forumites removed or are having dramas with their chip upgrades, got a big trip planned and would like to know more, anyone care to enlighten me, thanks.
    Nov 2005
    Maudsland, QLD
    Talk to MickG he knows all about problems with chips, he has had his chip in Bruce Davis's workshop more than it's been in the car!
    2023 Defender 130 D300
    SOLD - 2010 Discovery 4 V8
    SOLD - 2008 Range Rover Vogue L322 TDV8
    SOLD - 2006 Range Rover Sport L320 TDV6
    SOLD - 2002 Range Rover L322 TD6
    SOLD - 2002 Discovery 2 TD5
    SOLD - 1997 Range Rover 4.6 HSE
    SOLD - 1999 Range Rover 4.0 SE
    Gold Coast, Qld
    Re: who is this chip?
    Hi crump, still working through some issues with my manual TD5 which always seem to come back to the ECU. It has been looked at a couple of times and replaced once but my car is still not running as it should. In the new year I will be swapping it with a factory one for the day to see if that eliminates some of my drive problems, but until then I can't really say that it is definitely the ECU causing the probs. I'm 99% sure it is and someone who has had similar issues to mine and knows a lot more about it would be Greylandy on this forum.
    Good luck with our search and if you fit one and don't have issues, you wont regret it. Mine worked first class for a week in July this year and you couldn't take the smile off my face - turned to mud again though and i'm still troubleshooting.
    Aye, Mick
    '99 Manual TD5 D2.......heap of money spent on it and it has ended
    Ferntree Gully VIC
    i've had my chip in mine from new, well almost new (3 weeks)
    never had a problem with it yet
    130's rule
    Eidsvold QLD
    I actually had the ECU replaced not just a flash the chip job, dunno if that makes a difference, but when you say problems, what are we talking about, it runs rough, it explodes, it stops, exactly what?
    Gold Coast, Qld
    Since fitting my chip I have the following probs;
    Lack of throttle response - judders and sometimes stalls when taking off at lights. Down on power, blows plumes of smoke at lower revs, low down torque is woeful, gear changes are not as smooth as they used to be, jerky sometimes when coming on and off throttle etc
    To fill you in a bit more whi may help, mine is a '99 TD5 with 128,000 on it, 265/75R16 muds, 4.11 diff gears (which should bring the gearing back a bit further than standard due to the 31"tyres)
    Aye, Mick
    May 2002
    Sydney, Australia
    Greylandy had issues - think its now been removed
    Noddy had issues, but seemed to have them fixed - currently on a 12 month trip around Aus and no issues about chips from what I've heard.
    LRH
    Disco 4 SDV6 Auto
    Disco 4 SDV8 Dual Cab Project
    Disco 2 M57 Extra Cab Project
    Foton Tunland Cummins ISF
    Disco 1 3 door 4.6 V8 Auto
    RRC V8 Auto "Classic" Softdash
    RRC 300 TDI Auto
    Disco 1 TD5 Auto Buggy
    Disco 1 300 Tdi Auto Ute
    SAME Explorer 70HP 4x4 Tractor plus Nell Loader
    Subaru GDA WRX
    Triumph Bonneville SE
    Yamaha TTR250
    Ferntree Gully VIC
    mine is the same
    they plug it in and recode the ECU with the original land rover numbers
    and vroooommmmmmmm off you go
    130's rule
    Williams West Aust
    Hi Hiline
    From what I recall reading on here,the ealier 99/00 TD5 actually need the replacement ECU,the later ones like yours is just a re-program issue.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Ferntree Gully VIC
    mine is a 2000 TD5
    130's rule
