Results 1 to 10 of 20
Thread: 20" rims,, cause I can't find what I want
    Tangambalanga
    Question 20" rims,, cause I can't find what I want
    Hi guys,looking for info regarding 20" rim options and tyres.
    I've been looking, but can't seem to find what I want. There's tidbits throughout, which is making searching difficult.
    Preferably, I "don't" want to hear about 18's or 19's please,,, I just want to know about 20's.
    So, at this point, we're seriously looking at getting 20's as our other options not looking good. I want black rims, I did think about painting mine like I did with the Defender, but with upcoming work schedules etc, I'm rapidly running out of time for the Easter break/trip.
    So first question,, is there a "better" brand option,, we're looking at a set of Advanti's at present,, can't think of the name, starts with "t" I think.
    Next is tyres,, again, have looked only at a couple, but the Nitto Grapplers are looking ok. Not wanting MT's, just AT's which are reasonably quiet on road,,, the Grapplers seem to fit the bill here (??).
    So, if your experienced with them, or you are currently using 20's, can you give us your thoughts on them please?
    Thanks in advance.
    Feb 2009
    Quote Originally Posted by Chops View Post
    Thanks in advance.
    Yeah if you want the higher load rated Discovery 20s there's not a lot around, especially in black. I'd have to think there'd be more than a few after market options with brake size not being an issue?
    You'd have seen Meccles is running the Nittos on his Sport and seems happy. I have Coopers and will probably try something else next if I can afford the changeover. They're ok and can be picked up good second hand, but not great.
    I think it depends a bit, too, how oversize you're prepared to go.
    Did I read somewhere there's a new Grabber out recently?
    Now 2016 D4 HSE 'Leo' and Steve the Triumph Speed Twin
    Then 2010 D4 3.0 HSE 'James'
    Then 2010 RRS TDV8 'Roger' w traxide DBS, UHF, Cooper Zeons, Superchips remap
    Then 2010 D4 TDV6 'Jumbo' w traxide DBS
    First love 2002 D2 TD5 'Disco Stu'
    Dec 2009
    Ranelagh, Tasmania
    Mine has the standard LandRover 20" wheels so I can't help you with Advanti question.
    I've been running the Nitto Terra Grapplers 265 50 20 for 57K now and they are probably 3/4 worn (not helped by worn LCA bushes for a time).
    I've been happy with them in that time, road noise is good, ride a bit harsh on the small stuff, dry traction good, wet traction poor, off road traction good and wear reasonable.
    The only thing that has been a problem for me is the wet traction, you have to drive accordingly and it is easy to understeer in roundabouts, wheelspin when accelerating and set off the ABS when braking.
    They have seen limited off road use (beach and dirt) but I have been happy with their performance. I've had one puncture due to large screw through the tread.
    Fuji white RRS L494 AB Gone
    2023 Ford Ranga
    Sep 2014
    Bathurst, NSW
    I have 19" tyres so can't advise from personal experience. However, my brother who has a Grand Cherokee with 20" rims last year got the Nitto Terra Grapplers. He and I are quite impressed. They work great with towing his large van. Good on dirt and did well on the rocks in Palm Valley last year. If I was running 20" wheels they'd be near the top of my list. Good value for money.
    2014 SDV6 SE, Fuji White, ARB bar, Fyrlyt 5000, Pioneer Platform, Traxide D4-5S, Maxxis 980 Bravo, GOE Compressor Plate, ICom-450 UHF, Red Arc Tow Pro.
    Elite Murray 2 Caravan 24'4" Tare-2917kg, ATM-3500kg
    Sep 2014
    Bathurst, NSW
    Might add. At Kings Canyon when leaving the First aid centre after visiting a friend who was in there. My brother on reversing out caught the front wheel with the Nitto's on the sharp edge of a concrete block near a post. It caught the sidewall and then went up over the edge of the concrete. Probably a 4-6" high edge. With any other tyre it should have ripped out the sidewall. However, it went over the block with no damage. I was pretty impressed.
    NSW SW Slopes
    A brother has 265/50R20 Nittos on his RRS. 2 tyres suffered sidewall damage on some inland WA/SA tracks but they are on the wider RRS rims that stretch the sidewalls, not the narrower Disco rims.
    Be VERY careful when buying wheels to ensure you get a REAL load rating over 1,000kg. Many won't handle anything without damage.. especially rim edges which are nothing like OEM wheels.
    Williams West Aust
    Send a pm to aaron40.
    He went 285/55x20.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Tangambalanga
    Thanks for the help and info guys,,
    Stuart, how do you mean your getting them second hand,, are there really that many around and not wanted/disliked, or are these from people getting rid of the whole rim/tire to go the 18" option?
    With the Nitto's in the wet,, couldn't possibly be any worse than the CC's on the Defender with no ABS.
    Mike, I believe the load rating on the rims I'm looking at is 950, but I'll be checking more. My info has come from a very reputable LR mechanic here in Melb who will be looking after my car.
    PM sent Andy,, cheers.
    Jan 2013
    Ashgrove Brisbane
    I have standard 20" LR rims and have been running Nitto Terra Graplers 265/50/20 for about 18 months now. probably about 20k km's. I echo the comments above, good wear, reasonably quiet, good in dry, can slip a bit in wet, however i think this was because I was used to the sticky Pirelli Scorpion Zero that was on before. Again just need to drive to the conditions. Would I get them again, YES.
    One of the good thigs about the stardard LR20" rims is that due to the narrower size the tyres do bulge a bit and that has saved the rims from quite a few scratches. Current rims look a bit like a smashed crab thanks the tight Inner West Sydney streets when i had the Pirelli 255/50/20 on.
