Results 1 to 10 of 12
Thread: Tow hitch questions
    Scarborough, QLD
    Tow hitch questions
    As previously mentioned, I'm a Defender owner and know 3/5 of bugger all about Discos
    My father has recently bought a Disco 3, and came around to get me to help him remove the original tow hitch lock as it didn't come with a key. So I removed it via the usual method regarding the pin, only to find out the replacement supplied does not match the original. This had us looking around for solutions and instructions.
    Then we noticed the Ritter conversion kit to move the OEM hitch up higher and away from the spare. This seemed like a better option. So, what's the go - stick with the original, or replace it with a conversion model? Also, do you need to remove the original to remove the spare?
    Williams West Aust
    If he isn't doing any serious towing off-road simply get a D4 version.You can remove the spare and they swap.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Scarborough, QLD
    Andrew
    Thanks Andy - how does the D4 version differ?
    Williams West Aust
    Different angle,doesnt sit as low.The D3 version is known as the plough.Its a direct fit on the D3.
    Andrew
    Jan 2015
    D4 top, D3 bottom
    David
    Everything is easy when someone else is doing it
    MY14 SDV6 SE Corris Grey
    Compomotive 18s : D697s : Traxide DBS : LLAMS : ARB compressor : IC-455
    Rhino Platform : GOE compressor, Tx & front bash plates, deluxe sliders
    Scarborough, QLD
    Thanks again - where's the best place to sort a D4 version, and how much are they?
    Mar 2016
    You can wait until one shows up on eBay, else many LR secondhand showrooms have them kicking around.
    2007 Audi RS4 (B7)
    Williams West Aust
    Put a wanted add up.
    Plenty of the D4 mob use a Mitch hitch wich renders the factory hitch of no use.They do pop up in the markets area,D3 blokes look for them.
    Andrew
    PeterJ Guest
    Quote Originally Posted by l00kin4 View Post
    D4 top, D3 bottom
    David
    So if we used the centre of the key hole as a reference point, or the locking pin if the D3 version has the same as the D4, how much higher is the D4 towball ?
    Thanks....................Peter
    Ocean Reef WA
    Looks about 50mm higher to me Peter. I'm going through the same exercise with our D4 but baulk at the cost of a Mitch Hitch.......ridiculously expensive as far as I'm concerned.
    I think I'll buy what LandyAndy has suggested which is an adjustable hitch after turning my present thing upside down and checking the ride height of the van. Vehicle and van are dead flat behind the Defender but I have to check it behind the D4 yet.
    Cheers.
    AlanH.
