Results 1 to 10 of 18
Thread: what now !!!!!!!!!!!!!!!!
    Ferntree Gully VIC
    ok guy's the wife's ABS and TC lights are on in her 97HSE 8O 8O
    also the brakes have faded
    why does everything go wrong at bloody christmas time
    130's rule
    99.87 MB
    If its anything like the Disco2, it'll be the ABS sensors. See if it clears, and also probably try new pads that dont squeel.
    Slunnie
    Ferntree Gully VIC
    just had my personal mechanic here
    bad news, the fault wont clear
    loss of pressure in the system 8O 8O looks like it might be the brake booster
    130's rule
    SYDNEY -in the shire.....
    <span style="color:blue">did they run an accumulator in 97...?
    a black pressure bulb thingy on the box with all the spaghetti plumbing....</span>
    Ferntree Gully VIC
    <div class='quotetop'>QUOTE</div><div class='quotemain'>a black pressure bulb thingy on the box with all the spaghetti plumbing....[/b][/quote]
    i think so
    it has brake fluid all over it
    130's rule
    <span style="color:green">the diaphragm inside may have died....
    it has a rubber diaphragm inside with pressurised gas on one side and
    pressurised brake fluid on the other side.....
    the pressure in the brake fluid(built up by the abs pump) gives a higher pressure
    than in the gas chamber side....this is what gives you stored boost for braking
    assistance....</span>
    after switching the engine off....how many pumps of the brake do you get
    before it gets hard to press....?</span>
    Ferntree Gully VIC
    <div class='quotetop'>QUOTE</div><div class='quotemain'>after switching the engine off....how many pumps of the brake do you get
    before it gets hard to press....?[/b][/quote]
    it dont 8O 8O
    130's rule
    dont what....?
    Ferntree Gully VIC
    it dont pump up
    the pedal stays soft
    130's rule
    <span style="color:blue">if you pump the pedal with the ignition off.....
    will it get hard after less than 20 pumps...?
    or does it feel like its just full of air......?
    and needs a bleed....?</span>
