Results 1 to 8 of 8
Thread: drivers side (LHD) mirror fault
    Jan 2016
    Netherlands
    The automatic dipping feature on my drivers side mirror (LHD) dips when I put the car in reverse, as it should, but when I take it out of reverse, instead of traveling back up to the original position, it travels the same distance down again. I can understand the BECM running this show and there is probably a sensor or something in there but I can manually get the mirror to go back up and mounting a different mirror there DOES work (though I wrecked the housing on that one) so I am a bit flabbergasted as to what that can possibly be!
    Anyone have any ideas or tips?
    -P
    Douglas Park, NSW
    It's a potentiometer fault, it uses these to tell the BECM where the mirror is in the housing. I have a car that dips up, not down due to this but I just disable the reverse dip now.
    Jan 2016
    Netherlands
    It can be disabled? How? I would love for that option to be turned off since I reverse a lot during offroading and it wears the motors in my opinion whilst it is not needed!
    -P
    Douglas Park, NSW
    It's in the Owners Manual but you just turn the key to Accessories (IIRC, might be Ign but not running), put the gear lever into R & then hold down the seat memory button (I don't look, just feel - it's the long one) & it will come up Mirror Dip Disabled or similar.
    Sorry to be so vague but it's just an automatic process I go through having a few of these on the road.
    Disconnecting the battery re-enables it though.
    Jan 2016
    Netherlands
    Thanks Scott! that worked flawlessly, my mirrors are now stationary. If I ever get down under, I owe you a beer
    -P
    Feb 2010
    3029 Melbourne
    It is definitely a fault within mirror, as I had same issue with Fantom.
    I tried swapping out switchpack in centre console - no help.
    Then I tried swapping out door outstation - again no success.
    So finally swapped out mirror - presto it works again!
    Handy having a spare car sometimes -
    Jan 2016
    Netherlands
    This mirror already came from my spare since I kinda ruined the original way back when I was still learning to off road properly. I guess I could take the mirror apart to find the pot-meter but I'm a bit hesitant to take the glass off/out. Chances are it'll break and I am not really sure how to do it on these cars anyway.
    -P
    Feb 2013
    Gosford, NSW, Australia
    Quote Originally Posted by prelude View Post
    -P
    The glass is held in place by clips, very easy to remove.
    I have actually become very used to the mirror dip and I find it really useful
    Steve
