Results 1 to 10 of 17
Thread: tee in accessories on EAS system
    Jan 2016
    Netherlands
    I have read quite a bit on using the EAS system of our P38's for other tools such as inflating tyres and what not. I intend to run my lockers from that system for ease of install, use and reduce the complexity of my vehicle (which is complex enough as it is )
    The consensus seems to be that the best place to tap into the air suplly is hose 6 which runs to and from the air tank. I am concerned though that this may cause the air dryer to quickly become saturated or water to build up in the airtank. Running a pair of lockers won't be any problem since the amount of air used is negligible but inflating tyres is another story
    Having looked into the diagram on how EAS works, the only solution would be to tee in to the air dryer circuit and either make a mechanical bypass from the air tank or make it so one can operate the inlet valve manually. Not sure any of those ideas are the way to go yet...
    Anyone have a better idea? thoughts? Please
    Thanks!
    -P
    Feb 2013
    Gosford, NSW, Australia
    Quote Originally Posted by prelude View Post
    Thanks!
    -P
    Hi
    I have teeed in near the valve block inlet
    Steve
    Jan 2016
    Netherlands
    Steve,
    Would that be the inlet from the compressor to the valve block, or the inlet from the air tank?
    Thanks,
    -P
    Douglas Park, NSW
    I've seen the drain plug at the back of the tank drilled & tapped for an airline if you don't want to disturb the EAS components.
    Jan 2016
    Netherlands
    though that is a very good idea, it still takes the inlet air through the dehumidifier but the air out bypasses it. I'm worried it'll kill that thing in no time, at least the filling. I have looked into an industrial dehumidifier but they are fairly big, expensive and cost quite a bit of air to operate, in relation to our tiny little compressors
    Douglas Park, NSW
    You could always run a small water trap (and regulator if you wish) like on workshop air compressors.
    Feb 2013
    Steve,
    Thanks,
    -P
    You can't get to the inlet from the compressor to the valve block, only the main airline which connects the valve block, the dryer and the tank
    Jan 2016
    Netherlands
    I'll look into one of those workshop traps. Smallest I could find so far is 40cm long so that is still quite a large cylinder. Not sure about how well they handle heat under the bonnet
    -P
    Douglas Park, NSW
    40cm??
    I was thinking along the lines of one of these:
    There's various sizes available but most are around the 20cm mark.
    Jan 2016
    Netherlands
    Would these dry the air as well as our inline dryers? It seems to me that the item you posted does not remove all the moisture from the air and the range rovers dryer, due to the filling, removes practically everything.
    I was looking at one of these, these are used in applications like spray painting since any moist in there will ruin your coating
    http://content2.smcetech.com/pdf/IDG-A_EU.pdf
    Am I beeing overzealous? (if that is the correct word for it)
    -P
