And why is a 1/2" drive ratchet dodgy ?
It fits it works and i`ve done it
1" = 25MM
Half of 1" is 12.5mm close enough.
 Master
						Master
						What size is the square key required to undo the transfer box fill & drain and the diff drain plugs? Best I could measure is 13mm? Bunnings hardware?
Do these have a name? Just thought that maybe a 1/2" socket adaptor might work....yeah yeah I know dodgy brothers .............
1" = 25MM
it's ½" square drive.
Thread is BSP.
If you want accuracy, check here:
Standard Square Drives for Socket Tools ASA B5.38 1958 - Engineers Edge
Roads?.. Where we're going, we don't need roads...
MY92 RRC 3.9 Ardennes Green
MY93 RRC LSE 300tdi/R380/LT230 British Racing Green
MY99 D2 V8 Kinversand
 Swaggie
						Subscriber
						Swaggie
						SubscriberGeez, A socket handle or male 1/2 whatever will be fine.
If it has the stupidly inaccessible filler plug like a D2 , you may need a 3/8-1/2 converter and a 3/8 wobble extension about 50mm? long to dodge the brake drum.
Regards Philip A
