Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: Roof load
    Jun 2016
    Newtown
    Roof load
    Hi, we're travelling from Sydney through the Simpson Desert to Dalhousie Springs and back. Apparently we're going to need 6 20litre cans of fuel. Our max roof load with the Rhino Rack is 75kilos. Do you think it's OK to exceed that for a few days til we use the fuel? There'll also be a 2nd spare and tent on the roof.
    Feb 2009
    Quote Originally Posted by saljosax View Post
    It's a lot, isn't it... Is a fuel bladder or rear mounted spare wheel/jerry holder an option for you?
    Now 2016 D4 HSE 'Leo' and Steve the Triumph Speed Twin
    Then 2010 D4 3.0 HSE 'James'
    Then 2010 RRS TDV8 'Roger' w traxide DBS, UHF, Cooper Zeons, Superchips remap
    Then 2010 D4 TDV6 'Jumbo' w traxide DBS
    First love 2002 D2 TD5 'Disco Stu'
    Aug 2015
    I've seen others remove the rear seats and use a drip tray to store them on ratcheted together. Might be a better option.
    Take it you don't have a long range tank?
    Sep 2014
    Bathurst, NSW
    You don't plan on carrying the whole 120 litres on the roof rack do you as well as tent and spare. The roof might physically hold that load although well in excess of design. I'd be really worried about stability.
    Carry the jerrys inside and put other light stuff on rack. Only put jerrys up on roof when empty.
    2014 SDV6 SE, Fuji White, ARB bar, Fyrlyt 5000, Pioneer Platform, Traxide D4-5S, Maxxis 980 Bravo, GOE Compressor Plate, ICom-450 UHF, Red Arc Tow Pro.
    Elite Murray 2 Caravan 24'4" Tare-2917kg, ATM-3500kg
    Jan 2017
    I have always avoided fuel in the cabin. One spill and that smell/fumes stays for ages and dangerous. My thought is place them on the roof and then keep filling the main tank at every possible chance to lighten the roof load.
    Feb 2009
    If the spare weighs 30kg or more, plus a tent of 20 or more, plus the rack, it'd be upward of 180 kg, maybe as much as 200 kg? That's kinda scary if you have to tackle a dune on an angle or dodge an animal etc?
    Aug 2015
    I think in this case you have no choice but to carry it in the cabin.
    Long range tank would be good if it's in budget.
    You're already exceeding the roof limit before the fuel.
    Apr 2010
    Northern Victoria
    Fuel Inside
    I have had no problems carrying fuel inside (diesel) , but in plastic jerry cans not steel. You need to test them first for leaks by laying them on there sides in the garage overnight, full of course. The trick with the plastic cans is to compress the sides before finally sealing them so the contents are under vaccum. I carry them on there sides with no leaks and no smells. Get pro-quip ones as they have straight sides, and dont leak.
    Ivan
    2005 D3, 245/70/17 STmax, Tvan, Traxide, Mitch hitch
    Brisbane,some of the time.
    Just to clarify,petrol or diesel?
    Dec 2011
    Adelaide
    Do it right and do it safe.....LR tank under the car. That much extra weight on the roof is asking for trouble especially off-road where momentum will multiply its effect. I know LR tanks cost but this is your family's safety (...in the middle of nowhere!).
