Thread: Camper trailer solar reg, fuse box wiring.
    St Helena,Melbourne
    4.28 MB
    I have my solar reg wired to the battery and now need to connect battery to fuse box, can i just pair up the input/ouput into one anderson plug going to the battery ?
    This is so i can just unplug the battery if i need to isolate or remove it.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Feb 2005
    Yep, sounds good to me.
    Sep 2010
    Perth WA
    I don't see why you couldn't as when you connect the solar regulator to the battery and the fusebox they both connect to the same terminals. Although I don't see why you would do it this way when it is just as easy to connect directly to the battery terminals and disconnect if and when required.
    More connections is more potential points of failure.
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by loneranger View Post
    But this will eliminate 2 connections which is my main reason for doing it.
    1974 VW Kombi bus
    DiscoMick Guest
    Wouldn't you have a single positive and negative between battery and fuse box and then the regulator connected to the fuse box? That way if the regulator fails you still have the fuses to protect the battery from overcharging by the solar panel. It would be double protection. Or is that what you meant?
    Sep 2010
    Perth WA
    Maybe I'm interpreting this incorrectly but won't you have an Anderson plug at one end and 2 leads connecting to the battery and then from the other side the Anderson plug with the solar regulator and fusebox connected to the Anderson plug terminals?
    The way I'm seeing it is you will have 2 connectors for each Anderson plug and 2 to connect to the battery for 6 terminals versus 2 connectors for the solar regulator and 2 for the battery for 4 terminals.
    May 2009
    West Gippsland - Victoria
    If what you are asking is .......... "can I connect my load (fuse box) directly to the battery terminals as opposed to the solar reg load terminals" ............... then the answer is yes. The potential down side here is that if you have a very smart reg that measures input power and output power to give a state of charge indication of the battery or use a regs programmable ability to switch load on and off then these features won't work. For 99% of solar reg users this is not a problem.
    Deano
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by DeanoH View Post
    Deano
    No , I have solar panel to reg using an Anderson plug then cable with eyelets to battery.
    Instead of having another set of cables from battery to fuse panel I thought o could combine the inputs and outputs (to battery) into one Anderson plug going to battery.
    1974 VW Kombi bus
    Aug 2010
    Sunbury, VIC
    Hi mate - Yes, my van is set up that way - works well and is simple.
    People seem to want to over complicate their setups most of the time, this solution is simple and effective.
    DiscoMick Guest
    I'm sure what you are saying will work, but is it the best way?
    Personally, as I said above, I would minimise the battery connections and run as many things as possible to the fuse block and then just have a single connection to the battery.
    If your solar regulator is say 10 amps maximum and it runs to a fuse of at least 10 amps then I think that should be fine.
    If I have misunderstood what you said then sorry.
