Results 1 to 10 of 14
Thread: IID tool new key programing - D3
    Jul 2013
    Hi all,
    I brought a new key from ebay, and have attempted to reprogram it with my IID tool. So far every attempt it has failed to program the new key. Has anyone had this issue before? Im might shoot gap diagnostic an email and see what they say.
    Shane
    2005 D3 TDV6 loaded to the brim with 4 kids!
    http://www.aulro.com/afvb/members-rides/220914-too-many-defender-write-ups-here-time-d3.html
    Williams West Aust
    Was it Russrobe who bought the Idtool to program a key???
    Memory aint what it used to be.
    You get that after half a century I guess
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Aug 2015
    Andrew
    Memory must be better than you assume Andy!
    Had no problems with the Ebay keys I bought(other than putting one through the wash 2 months later).
    Did you check to make sure you have the same frequency as the old keys??? Can't think what else could go wrong.
    You might have to delete some old keys first. You can only save a few at a time.
    Nov 2014
    Nirvana near Albany W.A.
    Only time I had trouble with ebay key not programming was a dud battery , they're not the usual 2032 battery as they are soldered to the PCB , I ended up replacing with a battery holder from jaycar and a standard 2032 battery , separate the cover taking note of the spring for the key blade , you should have at least 3.0 volts.
    Narangga's Avatar
    Jun 2008
    McMinns Lagoon NT
    Quote Originally Posted by shanegtr View Post
    Hi all,
    I don't know what the process is with the IID Tool, but with the Nanocom you re-learn the total number of keys you want to use. That includes both 'old' and 'new' - so if 1 old and 1 new then re-learn 2 keys.
    Cheers, Dale
    'The D3' - 2006 TDV6 HSE
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    Brisbane, Queensland
    This YouTube vid is a good instruction on using an IID tool to program D3 keys.
    Land Rover Discovery 3 (LR3) Key Programming with the IID Tool - YouTube
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Jul 2013
    Quote Originally Posted by Russrobe View Post
    I ordered the key with the same frequency as the working ones, however there are no markings on the replacement key that specifies the frequency so it could be wrong for all I know.
    Shane
    Jul 2013
    Quote Originally Posted by discorevy View Post
    I had a similar thought of the battery may be flat?
    Shane
    Narangga's Avatar
    Jun 2008
    McMinns Lagoon NT
    With the Nanocom the keys will re-learn without issus but if the battery is flat in the remote then they won't work - or only work once immediately they are re-learnt.
    Cheers, Dale
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    Jul 2013
    Just an update, I shot an email to gap to see what they had to say also. Definatly an issue with the key, and they have seen it a few times with the chinese knock offs. So I think I'll open it up and check the battery, if thats good then it looks like I've got a $70 piece of plastic
    Shane
