Results 1 to 10 of 17
Thread: Coffs to Broome D4 observations
    Apr 2011
    Coffs Harbour
    Have just reached Broome after a six day trip to Broome for a contract.
    I fitted new Maxxis 255/55/19 and a new battery which I charged overnight before setting off. I reset with my IID tool the battery replacement on the computer.
    The tyres performed brilliantly and were not as noisy as expected. The roads were wet, dry, flooded and covered in locusts between Kunnunara and Halls Creek; horrible stinky things full of crap. Cleaning is an ongoing nightmare.
    Using the cruise control it drives like an Indian or Asian taxi driver; accelerate, back off and repeat. It, at 110 kmh will go to 111 and the back to 109 and repeat. Bloody annoying after a while.
    I have a voltmeter in the cigarette lighter and over the day's driving noted the voltage changes. After start I would see briefly 13.7 and would settle to 13.0 for a while. Over a period of 8-9 hours the voltage would drop to 12.2 before climbing up to 12.7 and sometimes to 12.9. I admit once in the middle of nowhere and seeing 12.2 I was a little bit worried, but it never let me down. With the old 5 year old original battery I used to see 14.7 after start and often 13.4.
    A fantastic trip in a fantastic car with 145000km now. Permagrin intact!
    2012 Fuji White 3.0 D4, Rear view camera, Hi-line sound, E-diff, Xenon lights, ARB winch bar, Lightforce 240 50w HID. Brads sliders.
    Sep 2010
    Dunsborough
    Good to hear your experience with the Maxis. I've just ordered 6 of them to replace the OEM tyres. The voltage changes are a bit weird though, what caused that?
    Williams West Aust
    Its the way they charge.Once the battery is full they only charge on the over run,ie down hills etc.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Apr 2011
    Coffs Harbour
    I am assuming that with the kms each day that after the start, then the continuous running the battery was floating and it had to get down to a set voltage before charging started again.
    Greg, the tyres performed very well as I set off from Coffs to Port Macquarie where I had an audio appointment and then the Oxley Highway with all its twists and turns. It felt surefooted at all times with placard pressure. The ride is harsher compared to my Toyo Open Country which are my city set.
    Mar 2016
    The point of variable voltage alternators is to reduce fuel consumption by only charging when required. The car monitors the battery level and charges when required, and as suggested, once topped up, only on overrun etc, unless the float voltage drops too low. Sometimes tools to monitor something you don't understand are worse that trusting the system.
    As for the cruise, 2kph to me is unnoticeable physically as inertia on the body. Stop watching the dialsCoffs to Broome D4 observations, sit back and relax.
    2007 Audi RS4 (B7)
    NSW SW Slopes
    Quote Originally Posted by Plane Fixer View Post
    My 4.4 RRV did the same on its 1st drive home - most annoying cruising on the freeway. Your hunting could be caused by a sticky inlet isolation valve which could have also been mine's problem, having spent its 1st 3 years of life doing only a few city trips as mine's hunting soon disappeared.
    DiscoMick Guest
    The voltmeter in the cigarette plug would not be reading the state of the battery, but rather the amount of charge flowing through the vehicle.
    Once the battery is charged a smart alternator only puts out enough to keep everything working.
    That's different to the alternator in my Defender, which settles to a standard output.
    May 2015
    Mooloolah
    To clean up bugs from vehicle, I highly recommend Bowden's "Bugger Off" in conjunction with their "Debugger" (a microfiber cloth which has a particular weave).
    Using the "B.O.'' on myself, I rid myself of B.O. (I like the perfume).
    Williams West Aust
    Windex works really well too.
    Andrew
    Apr 2011
    Coffs Harbour
    I used a pressure wash to get most off, but will drop the bull bar in the hangar on Sunday. This will enable me to thoroughly clean behind the grill as I am worried about overheating if left there.
    I have ordered a new pollen filter to try and get rid of the smell. Locusts are disgusting things!
