Results 1 to 10 of 25
Thread: Doin' the Rover shake.
    joe Guest
    Has anyone seen this problem in a Range Rover?.
    Well what happens is that when I get to certian speeds the Rangie gets up this little shake in the front end that soon turns into a death rattle 8O .
    The stearing wheel will shake almost out of your hands! and the front right will jump up and down with grate force!.
    I have had a mate drive behined me and he sez he can see the front wheels "toggle" or shake from side to side as it happens.
    I have been chasing this problem for a while now and have done the following to fix it but to no avail ; I have renewed the swivel bearings on both sides , I have fitted new tie rod ends , Greased and tightend wheel bearings front and rear , All bushes are polly and in good condition .
    So I have done all the big things but no result! all I can do now is have the wheel alinement and balance recheked as i am a little sus of the last job done (dont you hate it when you find out they let a 17yo kid loose on your car :x ) . Has anyone got any clue as to what it could be?.
    The car is unsafe to drive till this is fixed so no mud and fun for joe .
    Maryborough QLD
    Maybe your wheel rims are buckled, have you got steelies or alloys?
    This can cause what you described. Your uni's, have they been done also? Shocks are also important and if they haven't yet been replaced, I would strongly suggest you do so.
    Also is there any suspension lift, anything over 30mm I have found can cause the front end to 'bump steer' causing the steering wheel to wobble especially if you hit a bump, etc....
    It's a process of illimination so check everything and you should eventually find the problem.
    Good luck,
    Trav
    A mate of mine had this same problem with his RR, and he ended up fitting this gadget off a disco that acts as some kind of inertial damper. I can see the part but I don't know what it's called. It's not the first time I've heard of this problem. Someone on here will no doubt be able to tell you exactly what to do
     2005 Defender 110 
    Adelaide Hills - SA
    Ummmm - what about your steering damper?
    Had a similar situation with my old Series II and an el-cheapo "no-brand" steering damper improved it no end.
    Defender200Tdi Guest
    Most likely to be the panhard rod bushes. Get under the front of your vehicle and watch the panhard rod mountings at both the diff and chassis ends, whilst you (or someone else) rocks the vehicle side to side. If you see any movement in the bushes, they'll need replacement.
    Paul
    On the beach at Hervey Bay
    Paul
    If it's not panhard rod bushes, it could also be lower control arm bushes.
    I have the exact same problem with my rangie ATM. I seem to have fixed it now.
    I have done:
    Offset lower control arm bushes
    new panhard bushes
    steering dampner
    new tie rod ends.
    Warburton, Victoria
    I had a very similar problem with our Disco.
    over 80kmh the front end wobbled like mad... but cornering hard stopped it...
    So i thought "steering damper"
    Changed to to find the same.
    Looked at the panhard bushes and found them to be in great condition.
    Then tried the trailing arms in the front. OK
    Then tried the steering for slop. Nothing...
    Took it in for a wheel balance. It was still the same....
    Rotated the tyres..... its gone....
    Well it does it over hard bumps... but ok..
    Only thing i never checked was the Toe out. i'm still to do that.
    So try rotating the tyres or another set. Weird ehh?????
    Jul 2003
    Mine is shaking as well. At about 100kph but not consistently.
    It's shaking up the Coopers Ale in the fridge 8O .
    I recently stuck the spare on the left rear after a spilt valve stem. So the imposter is going back to the rear door tomorrow.
    Mahn England
    Ex 300Tdi Disco:
    joe Guest
    Thank you guys.
    I have steel Sunnies and have rotated them all in turn.It made no differance .
    I did not think of the uni joints so I went and had a look. the front one has a little slop (about the thickness of a credit card).
    Also I have seen the tyres move from side to side when I rock the car . Its like the side walls are too week(soft).
    Anyway I will let you all know how I go over the next few weeks...........if I dont go insane first .
    SYDNEY -in the shire.....
    <span style="color:blue">have you balanced the tyres......?
    and have you checked the shock absorbers to see if they are working correctly.....?</span>
