Get battery tested or replace on spec. as a failing battery throws up all kinds of random faults.
Check EAS level sensors. I had a faulty one once that caused the compressor to keep running and overheat. My faulty sensor showed up as a flashing red bar on the 4x4 info screen ( not sure if the RRS has that screen though).
Also check fault codes if you can. Use the directory to find someone in your area if you don't have one.
Good luck!!
Matt
				Oztourer
MY05 TDV6 HSE, Buckingham Blue
Front Runner Slimline II roofrack and rear ladder, Safari Snorkle, Mitch Hitch, Traxide D3-DU, Bushman Fridge, Icom IC-440N UHF, Hema HN7, Tyredog TPMS, GVIF and reversing camera
