Results 1 to 10 of 16
Thread: OEM vs Genuine Struts
    duderduderini Guest
    If funds were not tight right now I'd be cool with genuine but the cost is staggering for 4 of them. Graeme suggested I get 4 new ones. Vehicle is RRS 2.7 2006 with 135,000 k on the clock.
    So any experience of the alternatives?
    I'd appreciate any input
    Nick
    Oct 2014
    Have a read of this thread:
    Air strut replacement
    Mixed experiences with non-LR.
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    duderduderini Guest
    Graeme was right
    Thanks for that. I might just have to stagger replacements and just buy the genuine ones.
    Thanks for the heads up
    Williams West Aust
    Importing your own from UK sellers may also save some coins.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    NSW SW Slopes
    If not already done, I suggest that you check that the air-spring is actually leaking rather than invest in replacements without checking only to discover that the corner still drops due to a leaking valve block or loose pipe connection. Put the vehicle at off-road height then spray soapy solution on the folds, the air fitting at the top and the front valve block.
    May 2010
    Dongara area on the Mid West Coast WA
    Expensive Bags
    It was fair to say the I had only begun to notice a deterioration in the ride of my D4 in recent times. That was not to say that I had any signs that the airbags themselves had given up. I discussed this ride issue with my local LR service agent. Their advice was that my D4 had reached the point where shocks were most probably 'shot' so to speak. They advised replacing the airbag and shocks as one unit and to stick with LR originals. When I asked re options they did say the could fit 'others' if that is what I wanted to do. I must admit to drawing breath when advised of the price to replace the shocks and airbags as one unit. In the end, after some research and consideration of price vs performance, I decided to take the plunge. I did not want to fork out all the loot in one hit so opted to stagger the replacements as discussed by 'duderduderini' below.
    I had the fronts done using genuine LR units and was astounded at the ride difference. I can only imagine what it would have been like to do all four at once. Anyhow I will be getting the rears done (genuine LR) in the near future so I am expecting that the ride will improve further.
    Oh, and just to give you an idea of how old the shocks and airbags were my Sep 2011 D4 now had just ticked over the 198,000k mark when the replacements were fitted.
    Linds
    Aug 2015
    Quote Originally Posted by LRD414 View Post
    Yep, went genuine, direct from Duckworths LR UK. Cheaper than I expected. Done at 200 000kms. Very easy job with the right tools, all of which are in the thread Scott linked.
    duderduderini Guest
    Ball park figure?
    Quote Originally Posted by Russrobe View Post
    Hey.
    Did you get all 4 sent out to you in one go? If appropriate what kind of dollars are we talking
    Nick
    Mar 2010
    back in WA
    Post
    Quote Originally Posted by duderduderini View Post
    Hey.
    Nick
    About to do mine (still)
    From UK source:
    • Genuine LR fronts £244.00 each
    • rears £286.00 each
    • Can also supply OEM Delphi units I believe they are Fronts £155.00
    • each rears £160.00 each
    • Shipping is circa £160-175 via UPS (Total)
    FYG - Genuine Shipped: £1235 - Approx AUD:GPB 1.598 = AUD1,974 + fitting (like a carton of beer if you do it yourself)
    Get a good wheel alignment to
    I added 30points to the spot exchange rate - but you are likely to get belted a fair bit harder on the rate what ever you use (pay pal 'gift' off shore etc).
    NSW SW Slopes
    Don't forget about GST and some lesser import duties on the total cost including shipping unless total item value less than $1000. Consider getting one set later.
    Changing assemblies doesn't necessitate a wheel alignment.
