The V8 petrol isn't as thirsty as the V6 petrol apparently.
Andrew
 Master
						Master
						I've gone from looking for a defender to getting a D3 HSE
Forgetting about fuel economy what is the perceived reliability of the diesel versus the petrol engines in the D3.
I'm looking at both versions and seeing significant differences in prices between the 2 models. When I do the sums, the savings on the petrol models will buy a lot of petrol and I wont be doing high miles.
I'm just unsure of reliability between the engines.
Any thoughts?
2012 L320 Range Rover Sport Fuji White
REMLR 012
No 5 Trailer ARN 177-295
2006 Disco 3, 4L V6 Petrol SE Deceased Feb 26 2023
SOLD Engineers Trailer - no id
SOLD RAAF 231194 Perentie 110 GS - SIR ANGUS
SOLD 4MP COY Series 3 FFR 30-209
Andrew
DISCOVERY IS TO BE DISOWNED
Snow White MY14 TDV6 D4
In the owners manual the V6 is .1 L/100 thirstier than the V8. I originally wanted V8 but i ended up getting an 07 V6.
I'm pretty sure that the V8 wasn't sold here later than 06, meaning you don't get the upgraded electronics (two cambuses, meaning no brake light cascading faults, general reliability, and stuff like automatic up passenger window).
 Master
						Master
						Like I said. Not interested in economy between the engines. Just interested in reliabilty of one vs the other.
REMLR 012
The petrol v8 & v6 are regarded as very reliable. The 4.4v8 is a Jag motor that was also fitted to the Range Rover Vogue and Sport. The v6 is a Ford motor also fitted to the Explorer. More info on v6 here.
Ford Cologne V6 engine - Wikipedia
The D3 tdv6 is a very reliable motor developed jointly by JLR, Ford & PSA, and also fitted to the Ford Territory and Pugs. Some more info here.
Ford AJD-V6/PSA DT17 - Wikipedia
It has had a relatively small number of bearing failures (even in the newer 3.0) and oil pump failures after the timing belts were changed at 160,000km service.
L322 tdv8 poverty pack - wow
Track Trailer ARN 200-117
REMLR # 137
