Do you have GOE wheels by any chance????
I found one of my sensor wires(left front) rubbing on the inside of the rim,a stick must have got it.Hadnt rubbed thru yet.There is a scratch mark on the rim where it was rubbing.
Andrew
 Master
						Subscriber
						Master
						SubscriberOn the way home from a trip towing my van I got the break pad warning message
i found this strange as I had just got the front done before I left and the back a month or so earlier than that
LR did the back and an independent did the front. I have read in the forum it may be the sensor, probably from the front
My new van has disc brakes and they were making a fair bit of noise. I asked the makers of the van a week or so ago and they say they are ok, not to sure.
Now for the strange bit, when I disconnected the van the message went away, or at least at the moment.???
WB
Andrew
DISCOVERY IS TO BE DISOWNED
Snow White MY14 TDV6 D4
 Master
						Subscriber
						Master
						Subscriber Fossicker
						Fossicker
						I have been reading some brake controllers are not too compatible with certain van disc brakes.
 Master
						Subscriber
						Master
						Subscriber Master
						Subscriber
						Master
						SubscriberProblem with message sorted, rear sensor broken now for van brakes
WB
