There is no filter in the standard sedimenter. That's all it is - a sedimenter where the fuel drops into it and hopefully any water stays there. But you can disassemble it and clean out any crud that is in the bottom. You can convert it to use a 296 Delphi or Cav filter if you want to.
					 ) turbo, p/steer, RFSV front axle/trutrack, HF, gullwing windows, double jerrys etc.
