Results 1 to 10 of 17
Thread: Driving on Access Height
    Jun 2015
    Melbourne , Victoria
    It seems that I had to switch to access height to get in my garage with rooftop tent on it, once I didn't return to access height and damaged rooftop tent ladder, entrance. I decided to leave on access height all the time, either freeway and city. Using off-road height when needed, thanks for LLAMS to get out of trouble. Just wonder if it affect the computer systems or suspension itself, I always watch out those speed bump and slow down. It also lower gravity and head wind when I have my rooftop tent on it most of dry season. Any issues can be if driving on access height most of time?
    Gary
    MY15 Discovery 4 White, ARB Summit Bull Bar, Runva 11XP Winch, LLAMS, Icom440, GME 4705 High Gain Antenna, Redarc tow pro elite. 18" GOE Rim & BFG 265/60R18, APT Compressor Guard & Air Tank Guard. Outback Long Range Tank & Spare Wheel Carrier.
    Mar 2016
    Aside from the reduced suspension travel before you'd bottom out the suspension, you'd need to get the car wheel aligned at access height else your tyres will wear poorly. I wouldn't do it personally.
    2007 Audi RS4 (B7)
    Write a sign - stick it on the wall opposite your garage entrance..
    "Are you lowered to enter" Driving on Access Height
    Bunbury, WA
    My D4 has a terrible ride at access height as it bounces along on the bump stops (No LLAMS just factory settings). No way I would want to keep it there at speed? Just my opinion of course....
    Every hit to the bump stop raises stresses also...
    Mar 2007
    South Arm, Tasmania
    Quote Originally Posted by cjc_td5 View Post
    Same here. I lower mine to access height to reverse into my shed, otherwise the phone aerial smacks into the roof. If I forget to raise the suspension when I go out, driving down the laneway soon reminds me as I can feel all the bumps and potholes.
    Anyway, unless you are using LLAMS or rods to alter your suspension settings, you can't drive the vehicle down the road in access height. The suspension will automatically raise once certain speeds are reached - pretty sure it's 10 km/hr if you have not "locked" the suspension in access height, and 30 km/hr if you had locked it in access height. There's obviously a reason for this. There is no way that I would intentionally drive my vehicle at access height for any reason other than to "get under" a low obstacle.
    Cheers .........
    BMKAL
    Oct 2014
    I'm assuming Gary means Llams Low rather than true Access height due to the speed restrictions already mentioned.
    Llams Low is higher than Access and the ride is pretty good, so this would be the only practical full-time option but may still be too high for the garage.
    I think it would be better to work out a system to help remember to select Access or remove rooftop tent unless going on a trip.
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    Dec 2011
    Forrestfield WA
    I once accidentally drove several hundred km, fully loaded, on a very rough road (Great Central Road before the upgrade a couple of years ago) at Llams low and didn't even notice that I had it wrong. I had intended to go to Llams height 1 to slightly increase the ground clearance and turned the knob the wrong way so I reduced the ground clearance instead!
    That's the problem with the location of my Llams knob. I can't see the LED and I did it on the fly without looking. I was a bit horrified when I realised but there were no ill effects.
    Bob
    Must have been a smooth track or you were taking it very easy...
    Even at std height on the rail corridor I was bottoming out..
    You cannot drive at access height - it will automatically rise at whatever speed it is (I think 30kph) - if we are talking about LLAMS at onroad height -20mm then that is not access height (actually a bit higher) - with -20mm I can go to access height with out it rising as long as the car is level - any slope and it will not stay down but if I go to locked access height it will usually stay down. You cannot drive on it as it is just too harsh.
    I drive with my LLAMS at -20mm and have done so for many years. I have never done a wheel alignment and not noticed any unusual wear on the tyres - my current General Grabber AT have 60,000km on them (98% at -20mm) and are coming the the end of their life and have worn perfectly.
