From my experiences one would fit a replacement slave cylinder (not make specific) and make any adjustment (length of rod) so as one has a little free play, say a couple of mm. Then bleed and operate...the slave cylinder piston should then have enough travel to do it's job without over extending.
If that does not work then you have a mechanical problem such as incorrect replacement parts or wear in other areas such as clutch, release arm, release bearing or any other fixed moment.
Thirty years ago i came across a clutch release problem due to the fact that the gearbox had separated from the bell housing......lose bolts.
Also hydraulic cylinder seals have to be orientated the correct way to function properly...if they are fitted the wrong way around they will just pass fluid.
W
