Results 1 to 10 of 20
Thread: Trucking a D4 - any tips to give about tie down etc?
    JamesH Guest
    Hi All
    There is a possiblilty I might truck my D4 from Kunnie down to Perth. Have a mate who has done it a few times but he has a Defender so it is straightforward. I'm wondering about the D4. Should it be lowered to access height? Is there any particular tips about where the tiedowns should go.
    In my over-active imagination if you just drive it on and strap it, the slight leakage of air and self leveling may cause the straps to loosen and enable movement?
    thanks for any tips.
    James
    Jul 2013
    Most if not all will tie them down by the wheels so even if the suspension did lower then it should have no affect.
    Shane
    2005 D3 TDV6 loaded to the brim with 4 kids!
    http://www.aulro.com/afvb/members-rides/220914-too-many-defender-write-ups-here-time-d3.html
    Mar 2007
    South Arm, Tasmania
    Quote Originally Posted by shanegtr View Post
    Yep - one thing that I learnt in my days of working in heavy haulage and carrying cars etc on trucks regularly was that you should ONLY tie down at the wheels.
    I have seen lots of damage done by so called "experts" putting chains over towbars / through bullbars etc.
    Cheers .........
    BMKAL
    Bacchus Marsh Vic.
    Quote Originally Posted by BMKal View Post
    I've seen these "experts" doing their thing.
    Remember though, it's all about not missing out on the next load so short cuts are taken.
    Cheers, Kyle
    The Good Oil.
    When did you last visit?
    NSW SW Slopes
    If you have a diagnostic tool then best to put the suspension into transport mode whereby it lowers to the bump-stops when the ignition is switch off then raises when restarted.
    JamesH Guest
    Alas I don't have one of those but I will talk to them at the depot if I go down this path. A mate speaks highly of the firm. Enclosed truck etc.
    Williams West Aust
    James,is there a story behind your D4 needing a ride home????
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Oct 2013
    Old Toongabbie, Sydney NSW
    May depend on the vehicle. The Gap manual would seem to indicate only available for two models. Extract as follows:
    Transport Mode activation, deactivation (L322-02, L322-06)
    Not sure whether the Nanocom is different.
    martin
    NSW SW Slopes
    Transport mode is available on the D3/D4 even though the GAP tool may not provide an option to select it. It involves more than the suspension too to save on battery power, which is unlikely to necessary on a comparatively short trip.
    Williams West Aust
    It also limits the vehicle to low speed and gears to prevent theft.
    Andrew
