Results 1 to 3 of 3
Thread: Trouble shoot bad PSU OR?
    May 2003
    On The Road
    power outage last night, went to switch on this morning and fans spin for 1 second, so i get that much power. hard to test V as its on for such a short time,, but after a few tests it seems around 9V on yellow and 4 on red, swapped to second psu and same result. not 100percent on second psu condition,, weird conincidence same symptoms though,, no vid card connected, no ram beeps but its not running long enough for that i think,, i do get green light on MB when i switch the psu on,,
    Sep 2012
    Adelaide Hills
    motherboard could be shot.
    Current Cars:
    2013 E3 Maloo, 350kw
    2008 RRS, TDV8
    1995 VS Clubsport
    Previous Cars:
    2008 ML63, V8
    2002 VY SS Ute, 300kw
    2002 Disco 2, LS1 conversion
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    some power supplies need to sit for a few hours attached to nothing and they will come good if they have taken a hit.
    reseat your ram after cleaning the contacts with a pencil eraser, check for fine spider webs etc etc that may conduct power.
    remove the 24pin atx power plug and inspect for any corrosion or arcing. same with the 4/8 pin plug.
    check the motherboard for any domed or leaking capacitors.
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
