Results 1 to 2 of 2
Thread: Replaced rear door latch
    Dec 2008
    melbourne
    G'day
    So after about 10 yrs I decided enough was enough and replaced the rear door latch. Pretty easy really although one thing I noticed is that the door does look like it's sagged and was catching on the latch/ striker part so all I did was adjust it to makes it align better.
    After I tested the door I noticed that sometimes the new electric latch would work and other times just chatter....is there some sort of programming with the nanocom needed to make the latch talk to security ecu?
    Thanks in advanced!
    Bronson
    Jul 2014
    west of Transylvania
    No programming is needed for that, it's completyely plug and play...if the latch was new genuine it can be a bad contact or chaffed wiring where the loom enters the door, check connectors C0484 and C0483 cos the connectors in that area used to suffer from corrosion(give them contact spray anyway)....(see RAVE-Electrical library- Connector views)
