Thread: Under dash fuse box
    Jun 2016
    South East Queensland
    Under dash fuse box
    Can anyone tell me what the differences with the parts numbers for the under dash fuse boxes. My original one was a YQE 000110. I brought another one that turned out to be stuffed but its part number was YQE 000250 and I have seen other with number like VQE 103830, YQE 000251, YQE 103320. Mine suffered the leaky windscreen problem so I need one to fix the the indicators which are now not working. All from the Cyclone Debbie. Also forgot to mention that its a Discovery 2 2002 TD5
    May 2015
    Williamstown, Victoria
    Microcat, Microcat - Spare parts Land Rover catalogue in English has YQS101820. For both D2 variants.
    Build date 11th Oct 2003
    LROCV #1410
    Cambewarra, NSW
    The interior fuse box configuration changed at the Disco 2a update model (2003/2004) which used a YQE000251 - most noticeable external difference is an extra relay was added and relocation of the red fuse puller tool from the top left to the top right. For pre update models you need the pre 2003 fuse box. There were some changes along the way from 1999 t0 2002 with part number changes - unfortunately I don't have access to Microcat at present to look up the supercession part numbers. Someone else on here should have that information available.
    Cambewarra, NSW
    Quote Originally Posted by Bohica View Post
    YQS101820 is the part number for the interior fuse box label (stuck to the inside of the cover)
    Jun 2016
    Vin numbers
    seems that it depends on the vin number. thanks Gary for the info much appreciated.
    Jul 2014
    west of Transylvania
    Quote Originally Posted by gazk View Post
    +1 for that^^^, the YQE000251 will work only on facelifts beyond VIN .........3A771052 this one does not work well on pre-facelifts cos there are some circuit differencies.... all the other part numbers will work on vehicles built prior of the mentioned VIN, yhose are superseded part numbers of the same fusebox
    Jun 2016
    Thanks again guy for the info and thanks sierrafery for your knowledge.
