Results 1 to 10 of 12
Thread: Running the suspension at +100mm for regular driving?
    EricCooke Guest
    Good afternoon,
    I was reading a thread on Facebook and some LR3 owners were saying that they could drive at normal speeds with the air suspension 100mm over stock using the Llams unit. I asked about CVs binding and they said only at full lock and giving it a bit of gas. I am curious if anyone here has done this or had any experience seeing other do this?
    We have a similar unit to Llams available in the States but honestly we are way behind Australia when it comes to actually using LR3-4s for what they are intended. People are just starting to look at them for modding and true trail use. Up to now the majority have been mall crawlers.
    Any information you can share on running at extended heights would be greatly appreciated.
    Thank you,
    Eric
    2007 LR3 SEV8
    Feb 2009
    G'day Running the suspension at +100mm for regular driving?
    Probably goes without saying you wouldn't want to do it for long periods of time. It's a relatively strong drive train but aside from the usual issues with raising independent suspension (tyre wear/camber, strain on linkages etc), the ride is pretty awful and the handling at speed wouldn't be far behind...
    Now 2016 D4 HSE 'Leo' and Steve the Triumph Speed Twin
    Then 2010 D4 3.0 HSE 'James'
    Then 2010 RRS TDV8 'Roger' w traxide DBS, UHF, Cooper Zeons, Superchips remap
    Then 2010 D4 TDV6 'Jumbo' w traxide DBS
    First love 2002 D2 TD5 'Disco Stu'
    Feb 2009
    There's another thread running at the moment on the logistics of oversized tyres if you're interested in that kind of thing.
    Bunbury, WA
    Quote Originally Posted by EricCooke View Post
    Good afternoon,
    Thank you,
    Eric
    2007 LR3 SEV8
    Apart from the obvious issues around stability, I think the main concerns would be CV longevity and also struts. I have run my D4 at +100mm on undulating tracks and I could feel the struts topping out over humps in the track. Not something I would like to have occurring long term....
    Feb 2005
    I would have thought a minus setting when hooning around.
    Yeah you guys are behind the times by shipping defender 'perenties' out of Australia
    Jul 2016
    Good afternoon,
    Thank you,
    Eric
    2007 LR3 SEV8
    Aside from the issues that may arise, it's just not a nice ride with the bags inflated that much. That's one reason (most) people buy these rigs... The ride, don't understand why you would mess with with that for a non practical reason.
    Put the disco in super extended mode and drive over a speed bump, it's as solid as a rock. No thanks. Hahaha. Lift it to clear a obstacle, then drop it back down. Running the suspension at +100mm for regular driving?
    Jun 2010
    Central Coast NSW
    I reckon get a set of these...
    Bolt-on-Portale - Tibus Offroad - Tibus Bolt-on Portale Portalachsen Umbau bolt-on portals portal axles installation Mercedes Benz G Land Rover Jeep Toyota Suzuki UAZ Polaris
    Probably too expensive tho Running the suspension at +100mm for regular driving?
    As the others say the ride sucks at that height. I know you can get some spacers for the airbags, but you still have to worry about CV joints, and you will also likely need rods to keep the height sensor within its allowable range. But that should help of the car drops to the bump stops (you'll need to extend those too) as it should clear bigger tyres.
    Dan
    Ellendale Tasmania.
    For me if I was to drive around above normal hieght, then it would be +30mm or first setting of the LLAMS, but correct me if I'm wrong, LLAMS only goes to 80mm, first setting +30mm second setting +50 = 80mm, the're the only + settings I have on my LLAMS as far as I'm aware.
    Cheers Baz.
    2007 BMW R1200GS
    Dec 2011
    Forrestfield WA
    Its 30 or 50. 100 is subject to the D4 speed restrictions since it is +50 Llams or rods plus the Disco's +50 off road setting. Only the +50 or +30 is available at all speeds.
    Bob
    NSW SW Slopes
    The Llams 100mm is in reality only about 90mm but it is achievable on all but the very early versions using extra high/recovery mode meant for when an ABS fault lowers the vehicle to access height and therefore available at any speed. However the rear camber will be quite positive and the front not too great either unless an alignment is done at the height and as others have stated, the suspension is much too rigid which detracts from the vehicle's ability to ride bumps and its general stability.
