Results 1 to 10 of 18
Thread: Key items for servicing
    Feb 2009
    Dear Moderators,
    For those of us who know nothing but greatly benefit from those who do, can I suggest an idea for Sticky. It would be great to have a Sticky that covered recommendations for long-term preventative servicing. Not such much the details (maybe that could be a link to a specific post) but just key issues.
    For example, there is the dedicated post on having the (not so much) 'sealed for life' automatic transmission serviced. And in a recent thread about buying a 2nd hand 2010 D4, the timing belt was mentioned. In the post re $15k D3, there was mention of 'control arms'. No doubt there are other hard learnt lessons that could be shared.
    Just an idea.
    Williams West Aust
    Your wish is granted,this thread is as sticky as a bees hind legs
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Aug 2015
    Key item, blank that damn EGR off, if I had a pre 08 TDV6 D3 it would probably be the first thing on the list seeing as you don't need to worry about error codes.
    Dec 2008
    Prospect 2148
    Key item: transmission service - somewhere between 50k and 80k. If you want to keep it then this is essential
    Oct 2012
    Idea for a Sticky: key items for servicing
    Key item, change diffs and transfer box oils regularly with correct fluids. Capacity is very small.
    Feb 2012
    Darwin
    Key Item: Always ASK to have all software checked for updates. It is not a given this will be performed.
    Cheers, Mungus.
    _________________
    MY14D4HSE, Nara Bronze, E-Diff, Vision Assist, Surround Cameras, LLAMS, ProSpeed Sliders/Compressor plate, Mitch Hitch,
    ARB Summit Bar, Runva 11XP, Traxide D3-DU, GOE Comp. Rims, D697 265/60R18, Rijidij RWC, Fyrlyts.
    Oct 2012
    Key Item, regularly clean and properly adjust EPB at back discs for long life and trouble free performance. (And always release before driving off)
    May 2016
    Kalgoorlie
    Good thread Iannicky
    Quote Originally Posted by PerthDisco View Post
    iannicky,
    A Dam good idea, some good solid basic ideas for preventative maintenance will be offered to this thread. Some good advice already.
    Only just learning to use the forum, bit slow on computers.
    Pete.B
    LM2016
    Feb 2017
    Googong
    All serviceable filters
    heres a price list for the 4 servicable filters both genuine and aftermarket from Karkraft in sydney.
    Feb 2009
    Alternator — preventative servicing/replacement
    A summary of this thread <https://www.aulro.com/afvb/l319-discovery-3-and-4-a/258724-alternator-preventative-servicing.html> concerning the alternator:
    1. If you are thinking of preventative maintenance, 150K is about the mark.
    2. As with all preventative maintenance, it is a matter of balancing cost, consequences, where you drive, own mechanical knowledge etc (ie, a risk assessment).
    3. If your alternator is still working when replaced, think about keeping it as a (travel) spare.
