Originally Posted by
TheEntertainer
Hi, hope you had a great easter break.
I'm on the lookout to resolve the rattling rear sliding windows in the defender.
Garrison seem to have a good but costly solution.
From what i can see it looks like the velvet like inserts has reduced in size and now allows the windows to move and thus causing a rattle.
Thought it would be a good idea to see how you have worked around or solved the issue.
Thank you all
There seem to be all sorts of solutions. I have tried using large black drinking straws squashed in the channel and also the offcuts from cable ties which have provided some sort of 'relief'.
But what I use now is 10mm wide black Velcro pushed in the channel. Because this exerts some force against both sides (glass & channel) and sort of locks itself against the channel works well, and is very cheap.
Give it a go before you try a more expensive option.
Travelrover
Adventure before Dementia
2012 Puma 90 - Black
1999 Td5 110 Ute - White
1996 Tdi 300 Wagon - White
