Results 1 to 10 of 26
Thread: Tyre rotation pattern? Including the spare.
    May 2014
    Tamworth NSW
    Is there any preferred pattern for tyre rotation where there is a spare (5th wheel) to be slotted into the roation?
    Normally I've done a Cross shape pattern (FL to RR, FR to RL, RL to FR, RR to FL).
    Where should the spare go? From the back of the vehicle to ???
    Off which Hub should should a wheel go back on the rear of the vehicle?
    If it matters I'm rotating BFG M/T TA K02 which I believe are not directional. They have approx 5000km on them now, and 6 or so months.
    -Mitch
    'El Burro' 2012 Defender 90.
    Sep 2010
    Perth WA
    I use this pattern
    May 2014
    Tamworth NSW
    Thinking out loud, I'm thinking that the steer tyres will wear faster than the drive tyres, given that friction is the mechanism thru which a tyre can make the vehicle steer.
    I guess the pattern itself is inconsequential (as long as it moves tyres from lower wear to higher wear wheel locations), with the consistency of said pattern and frequency of changes as the biggest concern?
    -Mitch
    Sep 2010
    Perth WA
    I figure as long as I rotate around every 8 - 10,000km I'll be fine.
    DiscoMick Guest
    Isn't it important to rotate to opposite side as well as front to back?
    I have seen it argued that roads normally slope from the centre out to the edge, meaning the vehicle is on a slight slope and the passenger side tyres are carrying more weight than the driver's side.
    It was claimed that meant more wear on the outside tread than the inside tread, so to keep the wear even they had to be swapped to the opposite side as well as front to rear.
    Mind you, I've been lazy and haven't done that yet to the Defender.
    99.87 MB
    I work on the principle that the rear of the D2 is heavier than the front, based on weight station weights, and the drivers side is heavier than the passengers side based on how many lean to the DS. From there I replace the least worn DSR and most worn PSF.
    Slunnie
    Somewhat North of Cape York...
    The way you are rotating the tyres is probably less important than consistency. I always rotate in a counterclockwise manner, including the spare wheel.
    Johannes
    There are people who spend all weekend cleaning the car.
    And there are people who drive Discovery.
    Jan 2011
    Gippsland
    I have 2 spares and so have 6 wheels shod with BFG All Terrain A/T to rotate. Spares to the front - fronts to diagonal rear - rears become spares - repeat every 10,000km. I did the fifth rotation in December 2016. They're plenty chipped and cut up but still have 8mm tread depth in the centreTyre rotation pattern? Including the spare.
    LROCV member #131
    1999 build D2 TD5 Auto, Mantec snorkel, 2" LRA spring lift, ARB on board air, Ashcroft ATB, CMM air ram CDL shifter, swag & gold pans ....
    May 2014
    Tamworth NSW
    Lucky you've got the extra tyres. It's a problem I'd klove to have but nowhere for me to store the extra tyre+rim.
    I rotated the tyres yesterday.
    I have 5 tyres in the rotation.
    Rear tyres go to same side front position (ie LHS Rear to LHS Front, RHS Rear to RHS Front)
    LHS Front goes to spare positon
    Spare is fitted to RHS Rear
    RHS Front gets shifted to the rear, diagonally (ie LHS rear position).
    This was the recommendation by loneranger, (which also appears to be via the cooper tyre rotation guidelines for AWD and RWD vehicles with a 5 tyre rotation).
    https://www.coopertires.com.au/media...es-extract.pdf
    I'm not sure if it's a concern that the Rear to front movement means that for 2 rotations the tyre is on the same side of the vehicle? I know for instance, the forklift at work wears out the RHS tyres way faster than the LHS tyres. Apparently people prefer turning one way, given the choice. I guess round abouts might be a similar concern on the bitumen, and more agressive (read tyre wearing) turns may be taken on a LH turn rather than a RH turn.
    -Mitch
    May 2012
    Dalyellup
    Post #2 is generally the most widely accepted rotation pattern. This is coming from 25 years associated with the tyres, steering and suspension industry.
