I run a 3" on a hotted up TD5.... Noticeable power increase and note.
For a TDI a 2 1/2" with a single straight thru muffler would more than do it and cheaper too... But make sure its mandrel bent and directly from the turbo flange.
Mike
Hi has anyone had this mod done and doyou notice any power gains, thinking of fitting to '94 tdi, any info
Mike
On any turbo, I think the bigger the better, but on an off roader you got to think of clearanse too
Within reason!
Once you hit a certain point, performance per $$$$ soon drops.
On a TDI a 2 1/2" wont perform less than a 3" and is much cheaper option!
But for braggin rights go the 3"![]()
Mike - With 3" exhaust
What's the standard size on a Td5? (Too lazy to go outside and measure mine).Originally posted by tombraider
Mike
What muffler(s) do you have, I have been thinking about getting rid of the big one.
I have a 3" straigth through, no muffler on my Tdi Rangie
http://www.aulro.com/modules.php?name=Foru...ghlight=exhaust
LRH
Disco 4 SDV6 Auto
Disco 4 SDV8 Dual Cab Project
Disco 2 M57 Extra Cab Project
Foton Tunland Cummins ISF
Disco 1 3 door 4.6 V8 Auto
RRC V8 Auto "Classic" Softdash
RRC 300 TDI Auto
Disco 1 TD5 Auto Buggy
Disco 1 300 Tdi Auto Ute
SAME Explorer 70HP 4x4 Tractor plus Nell Loader
Subaru GDA WRX
Triumph Bonneville SE
Yamaha TTR250
mandrel bends are the go!
the key it flow and lack of restriction, the tighter the
bends the worse the system will be.
2 1/2 plenty big enough.
go the kubotas!
cheers phil
FWIW, OE diameter is 2.375"
OE TD5 is 2 1/2"
U can just remove the centre box and get a muffler show to make up a flanged pipe to bolt straight in.
Provides a noticeable improvement, and great note!
Mike
I think you blokes have just saved me about $ 500, so l my shout next time you come to Geelong. Thanks![]()
