L Series drops out of 5th on over-run.
					I've recently purchased a good condition Freelander 1 L-series diesel with the 5 speed PG1 gearbox that has done 290,000km.
When up shifting it works fine, but on over run it drops out of 5th but will stay in with light pressure on the gear stick. Also worth noting, is when down shifting from 5th, it is extremely reluctant to go into 4th even if you try double declutching. If it doesn't pop in it grates and will only go in (albeit stiffly) if you go back to 3rd and back into 4th. The clutch was replaced 10,000 km ago.
The other problem is a grinding/roar sound of either a damaged bearing or CV joint that is only apparent when in gear. With the clutch down coasting it doesn't make any sound. There is also a howl from the rear of the car but it could just be the aggressive pattern Continental tyres. The VCU isn't fitted so it is obviously not part of the problem.
Definitely the Morris/Perkins/Rover L-series sounds more Land Rovery compared to the later BMW Td4!
				REMLR Registrant No. 436
LROCV Member No. 1703
1976 RRC Suffix D
1979 Series III GS FFR
1980 Series III GS FFR with a Perentie RFSV tub
1991 Discovery 1 3.5 V8 3 door
1993 Discovery 1 200Tdi 3 door
1993 Defender 110 200Tdi ute
