Results 1 to 3 of 3
Thread: Isuzu 4BD1 water pump grease nipple
    Apr 2017
    NSW
    Why and what grease would you use and how often should the water pump be greased?
    When buying a replacement water pump does it make a difference to buy one with a water pump or not?
    Hay Point
    Quote Originally Posted by Defender3.9 View Post
    Any normal GP grease is fine, but don't overgrease it or you could do damage to the seal. One or 2 pumps when you do a service is heaps. And I think you mean "buying one with a grease nipple or not"
    It won't matter, lots including the turbo motor don't have a grease nipple. It was only on the industrial motors as fitted to 4x4's.
    Cheers......Brian
    1985 110 V8 County
    Apr 2017
    NSW
    Thankyou.
    Thankyou Brian, that clears thing up.
