From memory you can remove the heater air box ( engine bay ) to acess the air con bolts ( foot well)
 Wizard
						Supporter
						Wizard
						SupporterHi all
Has anyone had any experiance with the removal (and refitting) of the Aussie fitted air con facia in a TDi (TD5 the same)? I need to get to the bolts in the passenger foot well that secure the heater unit so I can remove this but they appear to be hidden behind the condensor.
Its this bit I need to remove....
Surprisingly there does not seem to be anything on YouTube about this.. Appreciate any guidance.
Travelrover
Adventure before Dementia
2012 Puma 90 - Black
1999 Td5 110 Ute - White
1996 Tdi 300 Wagon - White
'99 Tdi 300 130 Twin Cab
When I'm here I want to be out there.
 Wizard
						Supporter
						Wizard
						SupporterCheers
Travelrover
 Master
						Master
						On mine it was a nut and bolt arrangement.
Can be done without removing the ac.
Took 2 people.
One inside and one in the engine bay.
'95 Defender 130 Single Cab
HS2.8 TGV Powered
98% of all Land Rovers built are still on the road.
The other 2% made it home.
Cost difference between Britpart and Genuine seals: £2.04. Knowing that your brakes won't fail at any moment: Priceless.
 Wizard
						Supporter
						Wizard
						Supporter Master
						Master
						A ring spanner up behind the condenser from the footwell side will get to them, but its a PITA.
I did this job myself when the door and front fender were off...it was painful.
Best with two people, give the inside job to your mate, as its the worst position of the two
 Wizard
						Supporter
						Wizard
						Supporter| Search AULRO.com ONLY! | Search All the Web! |
