Results 1 to 10 of 14
Thread: gear lever and gear selection
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    every now and then I have real trouble selecting 1st / 2nd when stopping / stopped at the lights
    I have to quickly shuffle it thru reverse or 3rd and then try again, multiple times on most occasions.
    the gear lever is fairly sloppy.
    any ideas as to what would be causing this sort of issue?
    and any idea of how to fix it?
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    It is probably because the engaging edges of the teeth on first gear and the second gear dog clutch have been rounded by 45 years of inexpert shifting to the extent that they often can be in a position where the wedge on the edge of the tooth can't move the gear or dog to engage.
    Major gearbox work to fix, engaging the clutch slightly while pulling on the lever works, but needs expertise on the clutch operation.
    There is a slight possibility it could be the selector fork is loose on the selector shaft, but I think that is unlikely - it is also easily checked by taking the top off the box. Which would also allow you to see the edges of the teeth.
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    the box has always done it over the last 15 or so years but is now seems worse or I am less tolerant....
    will lift the top of it off in the next few weeks and take a peek.
    ta
    I usually get to the lights in second or third,
    pop it out of gear and take my foot of the clutch and wait until the lights are just about to change, pop it into 3rd or top to stop the input shaft spinning and slip it quietly into first.
    Safe Travels
    harry
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    Quote Originally Posted by harry View Post
    thats what I do, but sometimes no matter how you try you can't select first.....
    You may find that using a slipperier oil such as a synthetic may help.
    Serpentine WA
    No gear selection at all!
    Anyone got any thoughts on this subject? My SIII is currently sitting in a field and refusing to move.
    On the way to said field 1st and second gear was ok but 3rd and 4th sometimes difficult to find, almost as if they weren't there. A quick shuffle into 1, 2 or reverse seemed to sort it. Yesterday she was going great.
    On entering field nothing. I can select reverse but 1, 2, 3 and 4 completely impossible, it's as I'd the selector shafts have seized solid and all I can do is rattle the stick across the neutral position.
    When the gears worked, they worked fine.
    Hoping its something if to do with the selector springs or shuttle things, but they have only just been replaced.
    Any thoughts out there, I'll drag the lid off later in the week, once I get her back off the cows...
    Cheers Ian
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by inch View Post
    Cheers Ian
    Watch out for the detent balls and springs...
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    That sounds like either a selector fork is loose on a selector shaft, or there is a broken or missing selector spring.
    Serpentine WA
    Thanks Johns,
    Glad to hear it might be selectors or springs, been nervously looking at the price of gears and synchro rings!
    I'll pull the top off tomorrow and have a look. Springs are brand new so thinking selectors..... hoping selectors!!
    Got her back from the field with a little help from the young blokes 108.. the shame of it...
    Ian
