Results 1 to 10 of 17
Thread: Front hub bearing
    Dec 2009
    Tyrendarra Vic (South West Vic )
    Front hub bearing
    Has anyone changed the front hub bearings on a MY05 without all the factory tools. How hard a job. Have a grumble, not sure if it's that. But though I'd start there.
    NSW SW Slopes
    I tried one on my MY12 having fabricated a tool like the LR one but couldn't budge the shaft. The local mechanic eventually got the shaft out and back in but pretty much destroyed my tool in the process. Mine's shaft was a very tight fit.
    BTW, the bearing wasn't the cause of the rumbling, instead caused by pipes from the ABS pump vibrating together due to a spacer clip having become detached, a quite expensive misdiagnosis.
    Aug 2010
    Sunbury, VIC
    Haven't done the fronts, but the back ones on my 02 when I had it - bloody hard work getting the shafts out and back in again. Not sure how different the fronts are, but if similar they will be a battle.
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    Quote Originally Posted by Homestar View Post
    You talking about getting the axle shafts out from the rear diff, where the rave manual says use a soft drift and tap and they pop out. Bull that is almost impossiible as no room to swing the hammer of Thor , I used chain and put bolts through the links and screwed them into the flange, then had a mate with a slide hammer on the other end of the chain out side of the car and we got it dislodged.
    Dec 2009
    Sounds like hard work . Maybe too hard with my stuffed back & shoulders. Might have to leave this one the experts with correct tools . Just no one close to me . Nearest RR dealer about 260 kms. Bugger
    Aug 2010
    Sunbury, VIC
    No, getting the shafts out of the wheel bearings on the hub. Out if the Diffs is easy.
    NSW SW Slopes
    If mine needs any new wheel bearings (it sounds as though the rears are just as difficult as the fronts) then it will be done by a workshop that has the correct puller.
    I made a fork to lever the driveshafts out of the rear diff when fitting the e-diff.
    Dec 2009
    Sounds like a plan . Just a big trip . Minimum 500 kms
    Aug 2010
    Sunbury, VIC
    You can use a press if you have the whole shaft out, nothing special required.
    Brisbane, Queensland
    How many km do bearings generally last? I'm thinking pre-emptive maintenance.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
