Results 1 to 10 of 27
Thread: 2000W Pure SW Inverter choices?
    Oct 2011
    Fremantle WA
    My head hurts. Been looking for a good but reasonably priced ie value for money preferably AU 2KW inverter that I can use both in the car and the caravan for everything from daily charging tools to free camping.
    I'm not even sure if I need an inverter charger, or just an inverter, but would prefer one that does the automatic changeover to shore power thing for when used in the van. The options are bewildering, as are the prices.
    Anyone have a recommendation from experience? I'm hoping to stay under $1K, but?
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    That's a shed load of inverter!
    What you going to feed it with?
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Avoca Beach
    That's 166Amps at 12volts plus losses say 180 or so amps.
    You had better use BIG cables and have a shedload of batteries.
    Regards Philip A.
    Gavin. What are you seriously wanting to use it on? Specifics 2000W Pure SW Inverter choices?
    Oct 2011
    Fremantle WA
    Hi folks and thanks for responses so far.
    Uses include charging 18V hand tools in the car, and providing for SWAMBOS humongous coffee machine when off grid. Idea is for inverter to be portable between cars and caravan and usable for whatever comes up. (Not intended to be used for van A/C).
    Car has welding cables (70?) for battery leads and between 2 and 4 batteries at any one time depending on circumstances, so I have and can move the power. Caravan also has multiple batteries.
    So I don't need one quite so big?
    18v tools - look at charger requirements and that should help - or most brands make an 18v vehicle charger.. 2000W Pure SW Inverter choices?
    Coffee machines are the challenge... an inverter providing enough will be very expensive - and you'd almost want a Lithium set up to keep it happy - otherwise you'll have no power left 2000W Pure SW Inverter choices?
    There is an LPG coffee maker avail and likely 1/2 the price 2000W Pure SW Inverter choices?
    For what it is worth, about seven weeks ago I purchased a 2kW inverter from Jaycar for emergency use after my power system at home was struck by lightning. It is a 24v one, but I suspect they make an equivalent 12v one. It cost over $1500, but has no issues.
    Once you get over about 500w, the cost of inverters starts to get fairly high. And if you are on 12v, as mentioned, the primary current gets pretty high as well.
    One factor often overlooked when considering inverters is efficiency. Most suppliers only quote a single number, but in fact the efficiency varies with the power being used, and you can bet the figure quoted is the highest. Since this will usually be at close to maximum power, it is usually not a good idea to get an inverter that is bigger than needed. Look for short term ratings - and these vary widely. For example, my inverters that got killed by lightning are rated at 2kW, but will operate at 6kW for five minutes and 4kW for 30 minutes. The Jaycar one, rated identically at 2kW, will operate at 4kW for five seconds - but it is a quarter the size and a quarter the weight.
    From your posts, I would be thinking very carefully about the need for the coffee machine!
    May 2006
    Woolgoolga
    Oct 2011
    Fremantle WA
    Quote Originally Posted by gavinwibrow View Post
    Many thanks for replies to date.
    Well, I've checked the single bay 240V charger for my Makita 18V batteries, and all it says is Primary 220-240V 65W and secondary 7.2- 18V = 2.6A.
    So putting aside the coffee machine, what size inverter would I need for charging those batteries either with car running, or drawing from multiple car batteries as a starter please?
    Crafers West South Australia
    The toughest little inverter you'll ever buy is the Selectronic type used by the ambo's, plenty of people have bought these:
    Selectronic LD600-12 600W AC - DC Sine Wave Inverter 2 Outlet Camping Caravan
    They are second hand but perform way above their rating for short periods.
