Results 1 to 9 of 9
Thread: Fuel tank breather - did I just stuff up ?
    Jul 2016
    So, I have been spending weeks cleaning up my two under seat fuel tanks, soldering holes, applying rust converter, wire brushing etc etc, then on the week end I am cleaning up the fuel filler with a wire brush, and I decide to poke around with the breather, and hmmm, it seems blocked, so I thought that can't be good, so I grab the drill and drill it through !!
    Now, I think that may not have been the best move ever, and the other tank obviously has a springy flap of metal at the bottom of the breather tube.
    Have I stuffed up, and how can I fix this ?
    Mar 2013
    East Gippsland
    John I will have a look at my tanks tomorrow as I have hoses off.
    Cant be to much of an issue I would have thought as breather exits to main filler, probably Land Rover belt and braces design for if your on an exstreme slope or upside down but still can't see reason
    Will look at mine and post
    Cheers Paul
    Jul 2016
    Thanks Paul, I'd like to know the purpose of the breather, and how it's supposed to work. I originally thought it was to let vapour out if there's a build up of pressure, but I now believe it's to let air in to replace the volume of fuel being used.
    Any help appreciated.
    Mar 2013
    East Gippsland
    My tanks are non standard, aluminium but they have no obstruction in breather and car ran and functioned.
    I understand your concerns as I overthink also (first resto) but the more I get into my car I'm amazed at how logically they are designed and sometimes over designed
    Cheers Paul
    Apr 2014
    Blair Athol, Adelaide South Aust.
    I have two aftermarket fuel tanks on Betsy and they have no obstructions in the breathers either and the 2 standard tanks I also have lying around, dont have any obstructions either.
    Cheers Rod
    Sep 2012
    Westlake ,brisbane
    The breather allows the air in the tank out when filling otherwise with the nozel in the filler tube i& the fuel going in it westricts the exit & causes the automatic cut out in the nozle to cut the fuel flow. Also allows the tank to be filled to capasity if the filler tube goese in the side or below the top of the tank.
    I think you are overthinking it a bit - automatic cutoff nozzles were unheard of when the Series 2/3 tank was designed. The breather is there simply because without it, particularly when the tank reaches full while refuelling, and especially if leaning a bit that way, the air escaping from the fuel going in has to come out the same hole as fuel is going in, so it is going to spit fuel back at you.
    Venting for air to replace fuel as it is used, and with changes in temperature, comes in through the vented cap - except in the case of late model Series 3, where the venting is separate and via a charcoal cannister - but it still allows the air to come out separately from the fuel going in when refuelling.
    Sep 2012
    Westlake ,brisbane
    With out the vent the fuel bubbles back the filler neck as the air tries to escape. This makes filling very slow.
    Jul 2016
    Thanks everyone for all the checking, comments and advice. I think I'll just make sure the breathers are unblocked and leave it at that.
