Results 1 to 10 of 11
Thread: Air Suspension Leak
    Oct 2011
    Falcon, WA
    Air Suspension Leak
    Hi Guys and Girls, I have a 2016 TDV6 D4. I work away so often the car sits there unused for up to 12 days at a time........
    When I return home, the right rear air bag is down to its bump stops.........The rest of the car is ok.
    I have taken the car back to where I purchased it from 3 times now and they still can not find the leak.............How hard can it be??
    They claim they have pulled the air bag out and leak tested it and tightened all fittings??
    Does anyone have any ideas??
    Its a 4 hour trip there and back for me every time to the service centre and I am over taking the car back??
    Jul 2013
    Perth WA
    Hi, this happened to my 06RRS. I found it to be the front valve block. I removed the lines and gave it a good clean, never had the problem again. Not sure if it's the same set up on yours. You get access to it via the rhs wheel arch from memory. (RRS that is)
    Scott.
    NSW SW Slopes
    2016 still under warranty I assume so ask the dealer to change the rear valve block for starters, but really, just tell the dealer to do a proper job of diagnosing the fault.
    Oct 2011
    Falcon, WA
    Yep I'm hearing you Graeme! Might have to up the anti! I'm sick of their incompetence....
    Dec 2011
    Forrestfield WA
    Why not drive it to the dealer and leave it there for the 12 days and get a cab to the airport? That will give them plenty of time to check it out and see the problem happening for them.
    Bob
    Mar 2016
    Quote Originally Posted by BobD View Post
    With them paying for the cab of course.
    2007 Audi RS4 (B7)
    Bunbury, WA
    4hr return trip from Falcon, where on earth are you taking it? As said, just book it in at Southerns when you go away again. They are near the airport anyway.
    Oct 2016
    Perth, AU
    Agree with others, take it to Southerns, and start getting short with them. The suspension in these cars has been around since the first D3 rolled off the line, so there are no excuses for ****ty fault-finding skills any more.
    If it's down to it's bump stop in 12 days I should think there was at least some sag developing overnight - they should know pretty quickly if the problem is solved or not.
    2010 TDV6 3.0L Discovery 4 SE remapped to RRS output, Alaska White, GME XRS-330c, IIDTool BT, Dual Battery, Apple CarPlay, OEM Retrofitted: Cornering lights, Door card lights, Power + Heated Seats, Logic 7 audio
    Dec 2011
    Forrestfield WA
    Quote Originally Posted by cjc_td5 View Post
    I was going to say that but decided to bite my tongue!!
    He will have to get a later plane than the usual 5:30am flights though!!
    Bob
    Bunbury, WA
    Hi dwaters.
    My apologies if my previous response may have come across a little harsh. I live in Bunbury so trips to my closest dealer mean a whole day's work lost, which can mean a bit when one is self employed....
    Seriously, if only one corner is dropping, that would mean it would have to be either the relevant valve block, lines, bag or sensor on that corner only? Given that the bag is known as being robust and lines are easy to check, I would bet on the valve block being faulty.
    Chris
