Thread: Nanacom will not talk to ECU
    Shepparton
    A while ago I was playing around with the Nanacom and went into the security code function. I followed the instructions on the Nanacom, but it failed to get the codes. Now it will not communicate with the ecu.
    Jul 2014
    west of Transylvania
    On what vehicle?
    Shepparton
    Sorry forgot, it is a 2002 Disco II TD5
    Jul 2014
    Won't talk with which ECU?, if you played with nanocom in the BCU then it doesnt comunicate with the engine ECU but it still comunicates with the BCU i'll tell you more, also tell exactly what you was trying to do and in which menu
    Shepparton
    Quote Originally Posted by sierrafery View Post
    Will not talk to the engine ECU - trying to get into the engine ecu to check for fault codes.
    It was awhile ago when it happened. I will have a closer look at nanacom and try and figure out exactly what I was doing.
    Avoca Beach
    You have to turn the ignition to "on" or "om" if you are Buddhist.
    Regards Philip A
    Shepparton
    Got it working tonight. Went into a couple of other features first and then it started to communicate with the ECU
    Have no idea why it stopped working and why it started working again tonight - as I was doing nothing different than before.
    Thanks for the help.
