In a similar boat Laurie, looking forward to some feedback on this!
 Master
						Subscriber
						Master
						SubscriberHi all,
I am not in the market for a winch. I have no idea how to use a winch. I don't know if I will ever need a winch, but after reading some stuff I have a question or two.
I see winches as having 3 components. The cradle they are mounted on/in, the winch device itself and the electrics how they are wired in.
Ok, I want to deal with how they are mounted.
With the D4 I can see 3 mounting styles. Bullbar, hidden / discrete and finally the current Land Rover one that fits at the front. I am accepting that all are legal so let's assume that for a start.
Bullbars, personally dislike them based solely on looks. I can see their advantages though being able to mount heaps of gear and offering a bit of protection to the front. Some issues with air flow for cooling. Issues with sensors not working. Heavy. Some modifications to body so once it's on its on.
Hidden / discrete, my favorite as it does what the name says. You can't see it until you want to use it and then it's there. Doesn't detract from the cars looks. Major issue as I like the look. Now not sure about fitting to later model D4 but overseas websites say they are available. Looks like major work to install. They must restrict airflow. Minor cutting to body to fit. They have to be lighter than a bulbar so weight saving. There are some threads on these. Expensive. All the sensors & cameras work
Finally there is the winch mount that sticks out the front. I have seen one of these on a video on YouTube (Australian). I have not seen much discussion on them really and not found any copies you can buy though I am sure they have to be out there. Very expensive I have also read. Don't look as good as the hidden ones but better than a bulbar (personal preference). Wouldn't restrict airflow. Don't know about sensors and cameras. Keeps most if cars looks. Ease of access.
ok so reading about winches, in general. I have seen that the biggest issue with them is maintenance. Ensuring that they are going when you need them. Also read that biggest threat to them is mud. Now I can't see myself going through mud but dusty roads plus water crossing equals mud. So if you have to service these bits of kit it would appear to this novice that the stick out the front mount one is a no brainier. You can access it without having to take other things off. Have I got this right?
I can not see any advantage of one mounting system over the other for actual straight winching? Are there differences here?
I am not sure if you can add additional recovery points on a bull bar giving it an advantage over the other two systems when you use a pulley to bring the cable back for a double pull. I hope I got the terminology right there. So is there any advantages with actual winching capabilities with the 3 mounting system?
That's enough for now so I would appreciate any assistance in understanding the pros and cons of these and any other mounting system for a winch as it pertains to the D3/4.
All the best
Laurie
All the best,
Laurie
2019 sd6 SE
2012 SDV6 SE (Son stole it from me)
I have a winch. Most useless bit of kit on a Discovery......Only thing I've used it for is pulling the tinny up the dune at Gnaraloo station.
Mine is in a bar, as I like the other benefits of the bar. I had it on a Navara and when I changed it over, pulled it down and refurbished it. It had done a very muddy trip through the Kimberly for 5 weeks. When I pulled it apart, the gear box had a fair bit of mud inside, that had started to corrode one of the gears. So if you are doing mud and water you'll need to do maintenance. Pulling it out and putting back into the bar is not a great job, but doable on your own at home.
Gone 05 D3 ARB Front Kaymar Rear Winch E-Diff LRA Tank Dual Battery
Current 2015 SDV6 SE. Tow Pro Mitch Hitch Llams C/motives 70ltr w/tank 2 x comp Traxide BMS-2 x Aux 150w Solar Uniden Engel ARB drawer F/Runner rack Light bar
very interesting questions, Laurie.
I have to ask, if you, as you say , are not in the market for a winch, what is the purpose of your question? But let's put that to one side..
You are correct, if you have no idea how to use a winch, then you should not be using one. No amount of forum advice can teach you, so how it's mounted is irrelevant.
I think the best thing you could do is come out on one of the many days/weekends this forum offers and learn first hand. You could save some money, and learn first hand.
BTW, a winch is a winch. The car it is fitted to matters not.
JayTee
Nullus Anxietus
Cancer is gender blind.
2000 D2 TD5 Auto: Tins
1994 D1 300TDi Manual: Dave
1980 SIII Petrol Tray: Doris
OKApotamus #74
Nanocom, D2 TD5 only.
Laurie, we have a winch on ours in an OP bar, yet to be used in anger. Not sure how easy it will be to service at all, but removing the "underneath protection plates" should make it accessible.
The unit you mention which sticks out in front is probably a Warn Winch, and from memory look like they'd be easy to work on. I wanted this option, but the other half insisted on a bull bar,, and rightfully so as we do a few clicks in the country.
The Descrete one I know nothing of.
 Master
						Subscriber
						Master
						SubscriberWe all have our lists of yes/no/perhaps things. Lists can change. Most of my travel will be solo so I suppose it depends on how adventurous I get in the future if a winch moves from no to yes on that list.
Knowledge and understanding is never wasted. You never know what may come up tomorrow.
All the best
Laurie
All the best,
Laurie
2019 sd6 SE
 Master
						Subscriber
						Master
						SubscriberSorry, on the OL bar I have, and I think they're pretty much all the same, it has cover plates under it. I'm not sure how far mine go under, either sideways or deep wise, and I'm not sure if mine has a cradle attachment in it either, or if it's mounted straight to the bar itself, I'll see if I can get under and get a pic for you later.
So I would imagine that if they were removed, you'd have some access to the winch when in place.
We have a winch mounted on an Opposite Lock Bar also, winches are very simple things to use, if you have basic recovery skills, then a winch will be an easy thing for you to add to those basic skills just by observing others and a bit of hands on training, it's a piece of gear that just requires a bit common sense.
In my opinion a winch is very important if you do anything that involves anything steep or muddy or both, especially if you're towing as well, I've lost count on how many times I've used our winch, not only to recover us, but to recover others too.
Cheers Baz.
2011 Discovery 4 SE 2.7L
2007 BMW R1200GS
1979 BMW R80/7
1994 Yamaha XT225 Serow
Fair enough. I repeat, keep an eye on the "Upcoming Events" thread on this forum, and come out to something that is interesting and convenient. Nobody knows everything, and there is always something to learn.
Upon re-reading my reply, I find I sounded a little condescending. That was not my intent, so, sorry.
JayTee
Nullus Anxietus
OKApotamus #74
