From the ones I've seen, you put a new hole in the side/rear ( depending on the brand of snorkel) of the air box & plug the original.
HTH,
Larry.
Where tha @#$% did you / have you / would you insert a snorkle into the air box 8O 8O 8O
I really wanted to install a snorkle on her , but im kind of at a loss as to where to plug the hose into ----Les Richmond Automotive design -----
gulp-help
HTH,
Larry.
'51 Series 1 80"
'12 Defender 90![]()
Disco 4 SDV6 Auto
Disco 4 SDV8 Dual Cab Project
Disco 2 M57 Extra Cab Project
Foton Tunland Cummins ISF
Disco 1 3 door 4.6 V8 Auto
RRC V8 Auto "Classic" Softdash
RRC 300 TDI Auto
Disco 1 TD5 Auto Buggy
Disco 1 300 Tdi Auto Ute
SAME Explorer 70HP 4x4 Tractor plus Nell Loader
Subaru GDA WRX
Triumph Bonneville SE
Yamaha TTR250
Where do I get my hands on a Tdi Rangie?????
P.S. How do I upload my own avatar?
Robbie A.
95 Disco Tdi Auto
Robbie A.
95 Disco Tdi Auto
send incisor a PM and then he will resize it for you and send it back![]()
if your lucky :wink:
130's rule
If you're lucky you'll find one for sale.Originally posted by wozzlegummich
Otherwise it's a "build-it-yourself" jobbie.
Find an older Classic rangie, purchase.
Find a Tdi Disco or Defender at a wreckers or auctionhouse that's been rolled but engine is still ok, purchase.
Remove engine from Rangie, replace with engine from Tdi Disco / Defender.
Gee it sounds so easy when put like that 8)
If you're lucky you'll find one for sale.Originally posted by Grizzly_Adams+--><div class='quotetop'>QUOTE(Grizzly_Adams)</div><div class='quotemain'><!--QuoteBegin-wozzlegummich
Gee it sounds so easy when put like that 8)[/b][/quote]
For detailed instructions
http://www.users.on.net/~LRHybrid100/TDI.html![]()
LRH
Disco 4 SDV6 Auto
RRC 300 TDI Auto
Subaru GDA WRX
Yamaha TTR250
Here's couple of pics of my set-up. I tried the defender cylinder, but couldn't find an arrangement that I liked (anyone want to buy a defender filter housing?).
I ended up making my own box using the original Disco TDi filter cover and a home-made bottom box. The bottom box is modelled on the original Disco box, but with an additional bit for where the snorkle input comes in. It uses standard Disco 300TDi filters
Nice one Tiny!!!
I looked at using the Disco one, but ended up using the modified original EFI one from my Rangie.
LRH
Disco 4 SDV6 Auto
RRC 300 TDI Auto
Subaru GDA WRX
Yamaha TTR250
